edit: adding a factory light switch that has the fog buttons to this package. And the wires that can go from lights to factory fog plug located in some year mod bumpers.
$750 shipped lower 48, or $700 local to 19425.
Modular bumper bracket and Baja Designs triple light package that originally came from 4x4truckleds.
Not sae, these are the blindingly bright version, turn night to day, spot those deer, and keep moving package.
You will need a new harness from 4x4truckled to run from aux switch wiring to the lights. I traded the bronco and carefully removed the lights and brackets, but the harness that went from the aux wiring to the lights was left.
The brackets have some chipped powder coat from the mounting bolts.
The current cost for this package is over $1300. Save some coin and blast through the night.
Again, if you want to run these from the aux switches you will need to grab a new harness, I believe approximately $50 from 4x4truckleds. The factory boxes do have the Baja Designs wire harnesses so if you want to make it harder or more confusing to wire, you can always go that route.
