Baja Boss or A/T4W
mshaunf33
Shaun
Ohio
2023 Bronco
Can’t decide between 33” Baja Boss or 34” A/T4W… wishing the Baja Boss came in 285/75/17 but unfortunately it does not… will 1” make that much difference on the trails? Thanks for your input…
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
Since I spend a lot of time on the road, I went with AT4W’s. Weight was around the same, from what I recall, but the on road handling is better on the AT4W’s and they’re definitely quieter than Baja Boss AT’s (and MT’s). The AT4W’s look pretty aggressive too, so you aren’t sacrificing much on that front
both are 3 peak rated
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
There is a pizza cutter 35” Baja Boss.
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Personally, I run the Baja Boss AT on both my vehicle and my daughter's. It is very quiet on the highway and agressive off-road. It has an aggressive look and is a solid tire. Unitl something better comes along, that will probably be my tire of choice going forward.
vgodley1
Vee
Humble TX
Ford Bronco
Baja boss AT is my choice as well I do 30k highway miles a year and ther have been great
