Badlands with 33 or Sasquatch
vrtical
Doug AI
GSMNP, TN
Fords
And advanced 4x4 transfer case.
that is standard on BL, WT, FE, part of sasquatch on lower trims that only have part time.
  • Like
Reactions: jxc
Robertriley
Robertriley
JK, 36 ford convertible, 59 MGA, 57 Mercedes
What about offset (non-squatch BL)? Will be picking up an extra set of wheels for snow tires.
no, just seeing the looks of other wheelsets out there.
Robertriley
Robertriley
I have 35's on my 4-door JK and would most likely want to go that way again but my dealer said that with my late reservation and and wanting SAS it would put me into a 2022. We avoided the SAS, Painted top and other things so I could get a 2021. He said I should get it in October with what I ordered. They had slots for 61 Broncos and I'm at number 41. If I'm going to wait until 2022 to get it, I might as well go SAS. But I would forego the SAS if I can get it in October. Reading through the Forum and having a Nov reservation, does October seem out of the question?
JesseS
Jesse
Northern California
Jayco AY26, Honda F6B, CR-V
I am going BL non-sas, mainly due to towing it all over the country, the less drag the better, not to mention the added weight. I was going BD but the wife really wants the 'High' package.
Ponyup
Harry
Volvo XC60, Nissan Armada, CX-3, Bronco ordered
I wrestled with this like most people. I was all over Black Diamond but because I couldn't confirm if a standard BD could take a 285 upgrade without modification I went with Badlands. I was set on 33's but may upgrade to 34's. That's good enough for me. So I ordered a 2-door Badlands Rapid Red, 2.7 base tires with the High Package.
Wizard1183
Lafayette
2014 Sierra/ 2010 Camaro 2SS
Just do some research... it is not standard 4.7 gearing on badlands
Weird. It’s standard on BL 7spd cause I sure didn’t add it. Only thing I added was hard top and mid pack. But their packs are BS. BD with a mid pack forced me to 10spd. I guess mid pack on BL forces you to 4.7?
I suggest you do your research. 4.7 is standard on BL
jaspercasidino
PNW
2022 Bronco
It is a transmission difference. Non-Sasquatch BLs automatic gets 4.46, manual gets 4.7. Sasquatch gets 4.7.
Husker
N
F
Classic lovers who tend to be minimalists and maximalists who prefer a more aggressive stance.
Since ya mentioned Stance. From pictures, it seems like some SAS-equipped 2-Dr don't sit level. What is the consensus on the stance of a SAS?
Sean492
Sean
Canada
70 Ford Mustang Boss 302 and 2011 Ford F150 FX4
Was right where you are in terms of Sasquatch or no. For me, if not Sasquatch the badlands with optional wheels w 33’s was the only choice. I also now think that the narrower look is what I think looks better, so I went BL w 33’s I hated the wide fender flares. Can’t wait for delivery!
Ditto!
VelocityBrew
Minnesota North Metro
22 Badlands, 20 Passport, 16 1190 Adventure
Seriously you could search once or twice 🤷‍♂️
Ford Bronco Badlands with 33 or Sasquatch 1615921853143
Wizard1183
Lafayette
Initially it was stated SAS to get 4.7. No one mentioned transmission. Therefore I was correct no SAS standard 4.7. If you then opt for auto, THEN you must get SAS
so fact is 4.7 is standard on BL. You have to opt auto to be downgraded. Then upgrade to SAS to get it. Clarified enough? 👌🏻
nbennett14
Nathan
Illinois
13 Fusion, 14 Fusion, 07 Expedition, 14 Grand Cherokee SRT
It is only standard with the Manual on Badlands
vrtical
Doug AI
GSMNP, TN
Fords
its going to need a level kit just like the F150s
