Badlands "self squatch" finally done!
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
The blank slate: 2021 Bronco Badlands. 4 door. 2.7. High Package. Carbonized Gray. Soft Top. Took delivery 10/27. Ordered 01/29.
The usual accessories: Safari Bar. Rigid Pod Lights. PPF. Tint. Husky Liners. Valkyrie License Plate Relocation Kit.
How I made it mine: Ready Lift 1.25in. Level. 1.25in. BORA Wheel Spacers. 4Wheel Parts Big Tire Kit(modified crash bars). 315/70r17 BFG KO2s on Factory Badlands Rims.
Built Wild!
Do you thnk you need that much of a spacer? i like this but would like to go with as minimum amount of poke as possible, you think less spacer would still fit with no rub or your at the minumum??? Looks great!!
ProdigyJKU
2012 Wrangler
May just be the angle, but it looks like your front camber might be off a bit.
I put a 2" leveling kit on my BD and the alignment was way out of spec afterward.
Alpha1_Silverback
AARON
Ohio
21' Bronco Badlands
DeputyDawg
DeputyDawg
Forsyth, GA
13 F-150, 19 Expedition
BroncoAZ
Mitch
I read elsewhere that +30mm Sasquatch wheels clear 35” tires on the Badlands just removing the crash bars. That means a 1” spacer should be enough. Spacers aren’t legal in MA, so I’d have to change wheels.
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
i saw that too. looks like a positive camber now. and sort of lift (especially with that big of a spacer he put on) needs an alignment.
Alpha1_Silverback
AARON
Ohio
21' Bronco Badlands
Noice!! Looks like you had fun! No rubbing?
no rubbing...still had some room. Plenty of space between UCA and tire. I have 1.5" spacers so not sure if that is why or if it would have been fine with out. Just know zero issues yesterday!
Alpha1_Silverback
AARON
Ohio
21' Bronco Badlands
looks nice, i assume you are showing here much articulation and NOT rubbing??
Yes someone asked to see if there was rubbing when off pavement. no rubbing throughout the day.
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
nice! Thanks for taking the time to let us know. I’ll have 0 offset wheels, so should be similar set up.
Alpha1_Silverback
AARON
Ohio
21' Bronco Badlands
youre welcome. yes you should have no issues at all. so stock rims are +55 plus 1.5" spacer if my math is correct and if it is the correct way to figure it out, I have something equivalent to about a +17. Correct me if that is not correct way of calculating.
