I love my non sas badlands. I’ve did only 2 med trails which I just got it 4 months ago. What psi do you guys use for payment driving? Couple hour drive to get out to the wild wondering if tire pressure will help with the onroad portion
If I don’t go over 70-71 I can get 19-21mpg. If I drive 80ish or have a head wind, then in seen as low as 16mpgWhat kinda MPG do you get? Jw
I get 16.5. But, I drive almost exclusively with the doors off. Maybe that's why?If I don’t go over 70-71 I can get 19-21mpg. If I drive 80ish or have a head wind, then in seen as low as 16mpg
I can’t imagine how bad it will be next week when I’m running the rooftop tentI get 16.5. But, I drive almost exclusively with the doors off. Maybe that's why?
What about the backspacing on the rims. And did you add a lift at all?22 non-SAS Badlands 2.7 a/t. 35/10.50 17s. Zero rub full tuck.
on the badlands, to go from 33s to 35s, the only thing you need to do is remove the crash bars. no lift needed for that, and you should be fine with the 4.46 gearing.I have never lifted a vehicle before. I am considering getting a 2.7 on 33's, and then driving for a while to see if I "need" sasquatch. If I upgrade to 35's later and have the 4.46 gearing will it be that big of a deal? I am not going to go crazy with rock climbing. More of a family fun adventure vehicle.
Thanks!
That will be tight, my tires come close to the flares when flexed and I have 5/8” worth of spacer on all four corners. I am running the 315/70 KO2s, non-Sasquatch badlands.The factory 35's are wider than what I plan to run. The 11.5" wide should fit perfect with no lift, and keep full suspension travel. Especially with the beadlock capable wheels.
