Badlands Non-SAS - Your Thoughts & Pics?
_jeff
Central California
www.instagram.com
22 Bronco Badlands, 23 Lightning Pro, 14 FLD
There is one key difference if you plan to wheel more hardcore or possibly go much beyond 35s. The standard Badlands comes with two different final drive ratios: 4.46 and 4.7 in the automatic and manual transmission configurations. However, the Sasquatch package comes standard with 4.7.
So, if you'd like the mechanical advantage of the 4.7 drive ratio and don't want the manual (crawler gear is magnificent in 4L btw) then I would suggest going for the Sasquatch package.
And the small difference in clearance does show – I've wheeled with Badlands + Sasquatch and there were definitely sections where I tested the bash plates and others didn't need to.
All that to say, I think the standard Badlands with 7MT is the way to go if you like driving a manual.
MNBigfoot
MN
Stock badlands with upgraded wheels here. We love it. While it's not as tall, it does have more wheel travel, and considering most rigs I build are always low slung, with lots of tire and lots of travel, this fit right in. Once these BFG's wear out, will replace them with a set of Nitto 35x11.50r17's, and should be about perfect.
I thought the point of the more lift, less travel of Sas vs BLs is to avoid rubbing issues (at full compression) when going with 35s like you are doing. Seems like more wheel travel while being the right fit for 33's, would be the wrong fit for wheeling 35's. If I'm incorrect, could anyone explain the reason why the engineers at Ford limited the wheel travel on a $4000 upgrade package? Seems counter-intuitive.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Something had to have come up in testing, but I have yet to have any rubbing and I've stuffed the front tires many times.
DaddyMuffin
Los Angeles
A convertible, a station wagon, and a bus
I think _jeff hits the nail on the head
I have a manual badlands non sas with upgraded beadlocks. Like so many others have said, it’s more than enough for on-road driving with a cool look. I’ve also wheeled with sas owners and done everything they could do, but with extra skid plate touches.
So I’m going to echo - if you want excellent off road capability including for crawling, etc. Badlands manual non-sas is where it’s at for someone who wheels a dozen times in a year. If you are hitting tough stuff more often or don’t want a manual, then the extra sas expense may be worth it.
If you want to see some live sas vs non-sas action, check out this video from Trail Militia.
They were filming and spotting at Bronco Bash and posted my non sas navigating Hard Corner on Gold Mountain at around the 15min mark. I was the only non sas on this run, so if you watch the whole video, you’ll see good comparisons (plus lots of cool vintage Broncos and a Bronco Raptor).
Ford Bronco Badlands Non-SAS - Your Thoughts & Pics? 5A830DED-9154-49E9-B84D-1E02B923897F
Last toy
Penna
Bronco sport badlands
Nobody has mentioned getting the SAS package eliminates crash bars. That's a deal breaker for me. Can only imagine what Ford charges to buy them in the parts department.
eastbaybronco
Rudy
The East Bay Area
2023 Ford Bronco 4-Door CG Sasquatch 2.7
2 door you can get away with it. 4-door, Sas is a must or it just does not look right.
4avor8ntfair
Houston, TX
BL-non SAS, 2.3 auto
Very happy with mine, with the level kit! I wouldn’t mind a 1-2” lift, but I made it through 95% of Hell’s Revenge as-is…and I’d like to still be able to fit in the garage 😅
bikearch
Los Angeles Ca 91423
2014 camaro
Lov my non sas badlands. I can easily keep up with my sas friends and I got the mid package as most of the sas upgrades where not perfomance base but just nicities. I love the wash out provision in the floors.
AJKitebrder40
Adam
Charleston, SC
'23 Bronco Badlands 2D SAS, Eruption Green (Sold), '25 Toyota Tacoma TRD Off Roa
I'm in the same boat too......except the main thing I definitely want is MGV, so...I'm between a Black Diamond SAS and Badlands Non-SAS, price is basically the same and I lose front locker and disconnecting sway bar. I'm mostly using it as an overlanding/surf vehicle, with off-roading mostly on moderate trails in the NC/TN mountains.
My biggest issue with the SAS would be fitting it in the garage with a hard top and rails. I guess I really only need to garage park it in the summer anyways (when I take the top off).
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
It’s a few hundred. Not too bad.
BUT, kind of a mute point anyway on Badlands. Badlands already has front/rear lockers standard, so really the only reason to go Sasquatch on a Badlands is for the 35“+ tires. I could see someone buying a Black Diamond Sasquatch (for example) to get the front locker, and then downsizing to ~33” tires. But doesn’t make sense to do that on Badlands unless you just enjoy lighting money on fire.
Flourman
Centennial, CO
2022 F350 Tremor, 2019 Beta 300RR
A man with great taste there.
BroncoBarn
Illinois
2002 Wrangler
Completely happy with my 4 door standard Badlands. I went to the Off Rodeo in Moab last fall and chose the Badlands with 33s just to see how it would do. It handled everything the ones with Sas did and that is more than I will ever need. I actually like the look of the 33s rather than the wider flares of the Sas. I also was not a fan of the Sas wheels and tires.
We did the same thing at the Moab offrodeo because we have a non sas Badlands, no disappointments with the standard badlands.
Tricky Dick
Dick
PNW
cracKen
Ken
Washington
23 Bronco Badlands 7MT
What about the 4.46 vs 4.7 gearing though? I’m tempted to downgrade to a Base SAS to save money but going all in means I also get the 360 cameras and a huge screen for apple CarPlay.
