B&P updated once more
MayhemMike
Mercury
Checking out the B&P site and building two door OBX, there is now a few additional options listed. Front section soft top , door moldings, and hood graphic/ scoop. I have not seen these before this morning.
Big Boss
Outer Heaven
Bronco Big Bend
Hope to see locking diff and tow package on base as options for MY22..
Don't want to be Debbie downer but I doubt you will see that. The base exists to advertise a low starting price. I'm honestly shocked at the amount of options ot does have.
dingle87
Reese
West Suburbs of Chicago
2019 Ford Explorer XLT
For MY22 hope to see locking diff and tow package as options on base ..
I've been crossing my fingers on Base Tow package for awhile now.
tokyo
Utah / Japan
2-dr BaseSquatch 2.7
Yeah, probably not.
But I feel it is a more reasonable hope than the guys waiting for a manual V8
MUDLVR
Justin
Colorado Springs
2022 Badlands Sasquatch
Can you provide the website address? Thanks!
Mean Red GT
Kevin
TN
2022 4 Door Badlands/2016 Mustang GT PP
https://shop.ford.com/configure/bro...814-hp-return-visit-fix:rvv:na:na:ford bronco
Are you guys aware of anything the $595 "tow package" adds other than a hitch with wiring? Like a tow mode, heavier rear shocks, etc.? I held off because it seems it is only a hitch and wiring which are already available in the aftermarket for around $125...
Spooled
Republic of Texas
Raptor, Model 3
Doubt it. Ford needs the lack of those options to push you to Big Bend.
cowman
cowman
texas
ford
tokyo
Utah / Japan
https://shop.ford.com/configure/bronco/model/customize/base?intcmp=hp-rvv-fbcbuild-bronco&hptid=fv-2814-hp-return-visit-fix:rvv:na:na:ford bronco
As far as I know it is just hitch and wiring.
I don't believe it has a trans cooler or heavier rear springs.. So too your point, not a big deal.
The only thing that gives me hope for stand alone locker is it is an option on base (XL) F150 and Ranger, even with 4x2. So there is precedent for having it on the lowest cost stripper model..
Mean Red GT
Kevin
TN
Not with a 7 pin connector but in my experience the only purpose for a 7 pin is to work electric brakes and with only a 3500 lb towing capacity I doubt any trailer I would pull would be equipped with those. That was my thoughts on it anyway...
Thed
Ben
Raleigh, NC
'22 GX460 '16 Miata '67 F-100 '21 Streetfighter V4
You can get a Curt hitch for $112 or so plus tax. You can get the Ford trailer light adapter kit (four-pin only) for $88 before shipping.
For $200 plus taxes and shipping you're getting a hitch and four pin, and you have to install it yourself. If you want the constant power of a 7-pin, then you have to do some more wiring. This is the route I'm taking.
However, if you want a trailer brake, you pretty much need the factory tow package. It comes with a separate trailer light controller in the rear left cargo area. Plus it adds wiring to add a trailer brake controller so it can seamlessly work with the existing safety systems, like trailer sway control.
You can technically add all of that after-sale, but it would be more expensive. Programming the trailer tow module requires IDS and VIN programming, which means it'll have to be a dealer install.
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
All of the automatics have a trans cooler regardless of tow package or not. It's integrated with the radiator.
Manuals do not but it's also not as big of an issue for them staying cool.
