B&O subwoofer upgrade
2022 base
john
AZ 85143
1991 Chevy, 2004 Cooper S
Ford Bronco B&O subwoofer upgrade IMG_20240110_111158_111
With just a razor remove tab and this 8" shallow sub fits! You must remove beauty ring from woofer.
Ford Bronco B&O subwoofer upgrade IMG_20240110_111434_184
Ford Bronco B&O subwoofer upgrade IMG_20240110_110900_489
Ninjak
Miami
So a 8-inch is what we have there and needed. Did you run it off the same power from the B&O amp? I upgraded all of my other speakers except the sub. I do belive I have a nice 8-inch on my bench somewhere that I did not use.
jehines3
Easton, MD
Lexus RX350L, Chevrolet Silverado, Lincoln MKC
The factory B&O is a dual coil and a very small lightweight speaker. I'd go so far as to call it a woofer and not even a full subwoofer. Each coil was 4 Ohms when I tested it. I doubt that MB works well off the wimpy factory B&O Amp.
2022 base
2022 base
john
AZ 85143
I am using a 5 channel mb quart amp NA2-500.5 to run 200 rms to the woofer and 40 rms to the front dash and kicks. I chose to keep the 4" in the back factory power but upgrade to mb quart FKB110.
2022 base
2022 base
john
AZ 85143
Update....The woofer sounds fantastic in that enclosure with only 200watts!
mdube72
NH
Audi SQ5
Which MB Quart model number subwoofer is this ?
2022 base
2022 base
john
AZ 85143
mdube72
NH
Audi SQ5
Can anyone clarify what is +/- wire colors at the B&O factory subwoofer inside the box ? This diagram is not to helpful
Ford Bronco B&O subwoofer upgrade 10Speaker-2
Johnny Mo
Westchester County, NY
teachu2shoot.com
You have the wrong diagram there is a green connector that changes the colors that go into the sub enclosure see below. Inside the enclosure it goes to Yellow+ w Purple - and Green + with Black -. You can buy a connector and make it a clean connection instead of cutting - but the pins in the connector were flimsy and mine broke while crimping in my astro tool. so I just cut and spliced in my kicker key line level input connector. But if you are not running an amp these will go straight to your speaker terminals.
Ford Bronco B&O subwoofer upgrade 1668443137898
aptus
aptus
mx
ford bronco badlands non-sas
Did you test the mb sub with the b&o stock amp ??, I’m thinking only upgrading the sub , just to be sure that at least will sound better o more kick with the mb
aptus
aptus
mx
Where can I find the conector adapter of the b&o sub to a mb sub connector , thanks in advance
Johnny Mo
teachu2shoot.com
aptus
aptus
mx
