B&O bass roll off
budnr22
VA
22 Badlands
Hi -
I added a powered sub using the standard T-harness from Plug-and-play and LCi2 converter. I notice the bass seems to reduce significantly when I am driving. I have tried adjusting the speed volume and that does not really seem to do much. I disabled the Active Noise Cancelling using Forscan and I think that may have helped a little.
has anyone else noticed this?
cactusbase
Alec
NJ
Bronco BaseSquatch
Did you ever solve this? I am having the same exact issue with a Wavtech LOC into a 5 channel amp. Tune it, sounds great, start driving, has absolutely no bass in any channels.
WillinMA
Will
Groton, MA
2021 Wildtrak, 2025 BRaptor, 2025 G63, 2020 Lambo Huracan Spyder
I turned off the ā€œ speed volumeā€ feature and it seems to help. There’s a lot of discussion about whether or not it makes it louder or softer when driving around or at highway speed. And my guess is that it’s doing something to the bass.
budnr22
VA
22 Badlands
No. Still a bit of a mystery for me. Best I can do is compensate by adjusting the bass to be much hotter at low volume. No real answer at this time.
budnr22
VA
22 Badlands
it is off. I have always had it turned off. Good thought though
