Awning mount?
Cassell
Alec
Washington
Big Bend Sasquatch
Hey guys, I’ve got a hookeroad discovery rack and have a smittybilt tent on top. Is there any sort of mount I can clamp onto the side of this rack to hold an awning? I don’t really have space to use the tslots so I’m looking for an alternative.
Ford Bronco Awning mount? IMG_2999
Shooter Of Things
Russell
New Mexico USA
2023 Bronco; 2019 Ducati Panigale 959; 2012 Focus;
Can you mount to your tent?
I have an FSR tent and mounted my awning to the lower half of it.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
redone17
Cold Spring, NY
Does the Hooke have slots along the vertical sides of the crossbars?
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
While you are looking check out the OpenRoad. They have both a 270 and a 180 along with the walls. They are having an Autumn Sale going on right now. I think one of this should fit. Check em out. I have a Gobi rack and planning an OpenRoad 270 and eventually a hardshell tent.
Ford Bronco Awning mount? IMG_3132
Cassell
Cassell
Alec
Washington
Big Bend Sasquatch
I’ve got these slots along the sides, looking for some sort of clamp style mount that could hold onto the rack at those points
Cassell
Cassell
Alec
Washington
Big Bend Sasquatch
Not unless I drilled into the tent frame. It’s an older smittybilt hardtop so it doesn’t have any extra mounting points that I can see
DaddyO
Jules
Austin, Texas
Why don’t you contact Hooke Customer Service. They are good at helping you figure it out
DaddyO
Jules
Austin, Texas
dejones64
Dan
MN
Bronco 2-dr Black Diamond
I did this with my FSR Aspen Lite. Drilled holes in the bottom slats of the RTT to accommodate the awning brackets. Awning brackets are pretty much permanently attached to the RTT. I can remove the awning from the brackets if needed. I just keep it as all one unit now.
