Automatic windows issues
austin9294
Doug
2021 Bronco Badlands SAS
Is any one else out there in 6g land having issues when trying to roll up all or two windows at once were one will just stop and you have to wait till the other windows are up before that one will roll up? Seems to happen to me at least 3/5 times.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Yup, they have a mind of their own some days.
Hit a bump, it might stop rollin up. Try two at once, sometimes yes, sometimes no. Sometimes you get it rolled up and it comes back down. 🤷‍♂️ Whose to know
Migs1313
mark
Illinois
Bronco & Explorer
Yes having the same problem
XirallicBolts
Xira
Midwest, USA
2016 Flex EcoBoost, 2022 Silverado LT
Driver's side keeps faulting on the auto-up, even after trying the recalibration procedure multiple times.
Though it is a bit vague -- when I close/open the windows, am I supposed to pull the switch to the first detent, or all the way to the second Auto detent? Once the window fully closes/opens do I continue holding the switch for 4 seconds, or release and hold again
nikkgmm
Nikk
Los Angeles
'21 Badlands
Yep, same problem. I didn't notice I had to wait for the others to try and roll it up again, but I definitely have problems where they stop on their own on the roll up.
elnorte
Seth
Dakota
Same issues. Pretty annoying.
austin9294
Doug
Ok didn't know there were already that many with the same issue, anyone say anything to their dealer?
rayhil67
Ray
Douglassville pa
22 2dr Bronco, 06 hummer H3, 01 SuperDuty F250
My passenger window goes up then come right back down driver side fine only way to get passg side up is to open door and put it up till it stops at the "door open" height then goes up when close door..
" Driver's side keeps faulting on the auto-up, even after trying the recalibration procedure multiple times. "
And how does one do the "recalibration procedure" please!!!!
zgoods
Zgoods
MI
Bronco Sport Badlands
Count me in.
RUBronco
Jason
New Jersey
2022 OBX 2.3
I just came on here to see if this was an issue. Happens even on a single window auto-up - mostly passenger side.
Landin536
GA
VW Golf
If I try to auto up the front two windows, one of the two is guaranteed to stop going up mid way though
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Yup, now and then a window won't go all the way up. Haven't contacted a dealer.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
