Auto Stop/Start Disable (FORSCAN Method)
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Does anybody have any info on the programming needed within Forscan to disable the auto stop/start. Someone made another post but it's about the physical product.
I did this on my Raptor but since I didn't see any documentation yet for the Broncos I wasn't about to go in there and mess around.
Using the easy menus within Forscan I DID see one area that had the auto start/stop disable ENABLED. I DISABLED it but that didn't seem to do the job.
Wondering if anybody else knows which options (is there more then 1 spot) have to be changed OR what the actual values are when you go in via the advanced mode.
Be nice to have a sticky on this somewhere once it's figured out (I can modify this topic if need be and we'll use it as a sticky once it's verified).
NewBroncoOwner
Good Ol USA!!!
2021 Ford Bronco Base
Once the credits are available in HP tuners, I am sure that you can disable it within that program.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Herbie
Alex
Cleveland OH
2022 Badlands
I will absolutely look forward to hearing when someone successfully figures out the auto start/stop disable forscan setting as well as turning off the annoying door chime. I was kind of hoping the F150 settings would work on the Bronco, but didn't know how different the Sync 3 would be from our Sync 4. The F150 stuff I see on Forscan's site is all about Sync 3 or lower.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Did you manually disconnect and turn off bronco then turn back on? Did the headlights flash when you hit write?
jh3113
Jake
Phoenix
Subaru Outback
Page 8 of that other forum has a link to the Beta Forscan software where the guys says it worked for him. Did you try that software?
Rednek
Jimmy
Northern Alberta
If you put the truck in sport mode ASS is set to off
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Im running the latest. The thing is, the 1 spot I saw the start/stop didn't work. So I'm hoping someone has figured out the actual codes to change. On the F150s it was in a few different spots.
bytheway
Brice
Louisville, KY
sledboy
2021 Ford Bronco, RZR XP4 Turbo
I disabled Auto Start Stop through Forscan but it is not a very elegant solution. It "tricks" the system by modifying the "Charging System". So every time I start my vehicle, I get a message on my dash that says, "Charging System Service Soon". I have to manually press OK to get rid of the message.
I wasn't comfortable with this solution because if there is ever is a problem with the charging system, I would not know about it because of the false positive message that I get every time I start the Bronco. So I removed it in the hopes that a better solution will soon be found.
Desert_6G
Phoenix, AZ
Ranger
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Gpscharron
Claude
Waynesville, NC
2021 FORD Bronco, RV- Ford E450 (Thor Vegas 24.1)
There’s a plug on the negative battery terminal. Just unplug it.
