Audio question for someone that knows zero about audio
ColoradoSkiDreaming
Nashville
Have the reg. Non b&o system, which we all know sucks… I came from a fancy audio vehicle so it’s been quite the downgrade but the trade off has been worth it. That said, I want better sound… I don’t need the fancy amp thing on the tailgate or bumping base traumatize my kids… but I do want more depth and the ability to turn it up without feeling like I’m listening on my boombox from the 80’s.
My bronco is a 21 - can I swap out the standard audio for a newer model b&o and be fine? I found someone selling their b&o system for cheap but don’t know if swapping it out would do the trick… Or should I just upgrade a few speakers and add a kicker somewhere or whatever it’s called? I was quoted a 2k system on the phone but I don’t know that I actually need to spend that. I test drove a 24 the other day and the system was def better than what they put in my 21.
Anyone do just a minimum upgrade and been happy?
CUPRA
Jared
'21 Bronco OBXSAS/'23 Camaro SS Convertible
There’s definitely thing you can do to switch out the sound. As a B&O owner, I would not bother replacing what you have with the OEM B&O set up. It won’t make enough difference for you. We came from an 9 speaker Alpine system in our Jeep Grand Cherokee which was superb for a factory system to the B&O system which cost a heck of a lot more than the Alpine upgrade did in the Jeep!
This is what I did to ours WITH the B&O system to try and make it sound better.
If you do this, you will need to make some changes in Forscan to get the full benefit.
graham5david
Odessa Tx
2023 Bronco Base Sasquatch
Start here. You can't swap the BO system in easily. But upgrade your dash, kick panel and roll bar speakers with kickers listed in the video below. They are good speakers but if you want you can purchase better ones. The kickers sound great.
If you have a factory sub you can swap it out with a 4 ohm 6.75 inch kicker. Or by dremeling out the opening you can fit an 8 inch 4 ohm.
If you dont have a sub but have the sub delete then the sub box will be present with a fake sub and fake amp. You can install the sub mentioned above and order the ford fusion amp listed below and it is basically plug and play. If you have the sub deket you will also need to purchase forscan and turn the amp on in the cpu. Instructions are in the videos below. You can also buy a kicker downfire 10 inch sub with buit in amp for more bass if needed @RagnarKon has tons of information on this site fir this. Follow his videos on YouTube. Its honestly pretty easy and can be done for under 1k
https://teamequip.com/fomoco-fp5t-1...ystem-amplifier-for-ford-fusion-fp5t18c808ab/
I would not go B&O - it isn’t better than what you can do aftermarket with the stock system for a lot easier
1st 75th ranger
jeffrey
nj
i have a 2021 bd 4dr 2.7l softy mid pack ...the steroe was horrible
i kept the head unit added co axle alpines in deck and pods alpine mini subs in kickers
mti tail gate sub and box with amp and processor it thumping now with or without top
just change out to good speakers and small amp maybe tailgate sub also
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
Yes, this. I swapped in Focals and the difference is night and day.
BlarneyStoned
Apple-at-cha
Bronco, Land Rover
The B&O system itself isn't worth the upgrade, it's far easier to upgrade the base/high system if all you want is to have it sound better. Depending on how much space you are willing to trade in the process, the only part of the B&O system worth putting in would be the ACM so that you can get the A2B output and use the mObridge amp as an all-in-one 8 channel amp with DSP built into it. If you're on a budget just skip the B&O mess entirely.
