Ask a stupid question...get a..........
Bongo Fury
Bongo
Somewhere between point A and point B
2003 Ranger
I'm curious. Being a rustbelt denizen body rot is always a concern. Anyone have any experience with zinc anodes? Yeah, panels being an easy pull will be on the to-do list for rustproofing as will the undercarriage. What I'd like to have is a fully protected from the elements (salt corrosion) vehicle.
Zinc anodes just a myth?
RG7
B8 A4, 2018 Triumph Street Triple R
As far as I know those need to be immersed in water for them to work.
Fluid Film would be the tried and true option.
nwGTS
Nate
Chicago, IL
I'm curious Bronies. Being a rustbelt denizen body rot is always a concern. Anyone have any experience with zinc anodes? Yeah, panels being an easy pull will be on the to-do list for rustproofing as will the undercarriage. What I'd like to have is a fully protected from the elements (salt corrosion) vehicle.
The hood and all body panels are aluminum. sooooo.
You'll save a bundle by only needing to do the frame and doors.
Ford Bronco Ask a stupid question...get a.......... 2021-Ford-Bronco-Exterior-Panel-Materials-All-Labels-Front-Three-Quarters-1024x682
Mule
Miles
Alabama
Ford F150
This is called cathodic protection. Essentially this is already how your vehicles electrical system works. With your battery's negative terminal (cathode) hooked to your body, and the positive becomes your anode. Ships and pipelines use additional anodes on the outside of the hull and in the ground along with a continual electrical charge for protection.
Bad news... Electrical current stops flowing and you loose protection.
PWillette
Parrie
Maine
Zinc anode a myth in the terra-firmer automotive world however a galvanized (zinc) frame would be awesome.
GToddC5
Todd
South Jersey
www.bronco6g.com
PLEASE don't call us Bronies, that's the last damn ammunition that jeepers need:
Ford Bronco Ask a stupid question...get a.......... 1638993966552
StormtrooperS225
Ben
Alberta Canada
2021 Ford Bronco BD
Just use Fluid Film that's my plan and I have the same problem where I live
Bongo Fury
Bongo Fury
Bongo
2003 Ranger
2021-Ford-Bronco-Exterior-Panel-Materials-All-Labels-Front-Three-Quarters-1024x682.jpeg
Looking more to mitigate galvanic reaction between the aluminum body parts where steel floor/frame connection points occur. But being over cautious with preventative measures I might consider full coat due to oxidative conditions being a real potential.
fergthulhu
Sean
Aurora, CO
'22 Badlands, '21 Ranger Tremor
Completely unrelated question. Can you return personalized plates?
