ARCHETYPE RACING | RUTS - Ruggedized Utility Trail Sights
Status
Not open for further replies.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
What if we don't want a roof rack, but DO want limb risers? Will you guys make a bracket that attaches to the mount points above the windshield, yet still allow the painted caps to attach for a clean look?
It wouldn't be an ARCHETYPE part if it were any other way. ;)
LSU Jonno
Huntsville, AL
2022 Bronco
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
We're moving right along. I'd say 90% complete and almost ready for prime time.
We'll have a full billet trail sight that mounts to the modular base plate. Weight rating, at this point will be limited by what the fender can support, not the plastic trail sight. With the modular base plate, you can swap between the trail sight delete for a smooth look or easily swap to the trail sight. The ultra clean stainless cable limb riser is is an add on. With our upper mount on the soon to come roof rack, it will not be necessary to remove the limb riser to fully open your hood. There are 'hidden' M8 threaded locations on the top of the trail sight. These will be used for the upcoming mounts. Think HiLift Jack... proper beefy stuff. This will give those that want it, a real overland/exploration look.
We're running prototype parts this week. Actual photos soon!
actual photos getting close?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
They're being machined now. I hope to have them fully finished and installed by the end of the month. That's probably an aggressive date. We have so much coming down the pipe and the pipe isn't getting any bigger.
Smheard
Sean
Jenks, Oklahoma
‘19 Raptor, ‘21 Macan S, ‘22 Big Bend, '21 FE
Are wheel options part of that "coming down the pipe"? ;)
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Are you tapping into our super secret meetings, Sir?!
As a side note, are you pumped for the college football season?!
Smheard
Sean
Jenks, Oklahoma
Maybe as I could possess secret sauce telepathy and yes on CF....although I'd be happy to see communist OU go ahead and move to the SEC now so they can begin getting their asses handed to them immediately. ;)
F OR D
BD Green Machine
jfc you guys need to chill. my wallet is taking a beating.
Sandbergo
Jelani & Dave
Orlando
Rogue
Good to see that the front line lines up with the fender and hood correctly. Seen some of these done with that front edge just being straight and couldn’t understand why they didn’t make it line up.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
I'll need to check up on these and follow up. We sent the designs off for machining a while back. I would expect them soon. I added some other projects ahead in the mix that bumped the trail sights a bit.
GravyTrain
Greg
Oklahoma
LR4, 2020 110
The forgotten product. Guess it wasn’t a popular idea?
j_anderson
Fort Wayne, IN
www.instagram.com
AR | RUTS : Ruggedized Utility Trail Sights
Accessory #3. Some of you have asked for it and we're doing it! We're taking the OEM's mixture of plastic and metal and cranking it to 11! The RUTS will be the foundation of a line of accessories that I think will become the Swiss Army Knife for mounting and stowing of readably available off road or overlanding gear. We'll forgo the plastic cap for full billet construction and really anchor it to the inner fender for really robust support. I'll retain a lot the OEM look with the nuanced BRONCO grill look to the opening and mechanical hardware, but the RUTS will be capable of so much more. Think HiLift jack, Maxtrax, aux lighting, recovery cables, fishing poles, limb risers, GoPro, flag, antenna, lashing locations for a kayak, long boards, paddle boards, canoe ... you name it. If there is a use case for additional mounts or adapters, I'm all ears.
This is a larger and more complex part. I'd love to have it ready for SEMA but that will be an aggressive goal. We'll see.
patiently waiting for someone to design a trail sight replacement with turn signal indicators facing back at the cab like the 60/70's vehicles had.
LSU Jonno
Huntsville, AL
2022 Bronco
Status
