ARB Zero Series Fridge Freezers
Status
Not open for further replies.
Stage 3 Motorsports
Stage 3 Motorsports
Joel
www.stage3motorsports.com
2021 Bronco Badlands 4 Door 2.7L Ecoboost
Being I havent had much time around the Bronco just yet these are great comments.
We do have many of the sizes in stock so if anyone is in the market shoot me a message and I can get you a good forum deal.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
You've seen a 63 or 73 fit the same orientation as your 47 (handle towards the rear)? I'd like to see one in the back of a Bronco with back door closed before dropping $1500.
It will be close. Especially with the flat 12v plug - it should JUST make it.
Ford Bronco ARB Zero Series Fridge Freezers 5B26F655-EBDF-4C46-93C7-842F4CCCDA67
I have the cargo cover - which you lose roughly 3/4” in the back from the sidewall.
Ford Bronco ARB Zero Series Fridge Freezers 74436DFC-2789-4295-8DBD-67EBC71ED823
BroncoAZ
Mitch
Same as above. That being said - I jumped the gun and should have went bigger. Looks like 63 and 73 are the same size footprint. 73 is just taller.
I lived out of these fridges commuting for a few years. I could get 5 days worth of meals into my 37 quart, drinks were stored warm and added as I made space. I had a 50 and a 37 with the same footprint. The cooling mechanism appears to be the same and the shorter unit worked better in the Phoenix summer in the back of a SUV. Precool them on 110v before leaving, and keep them as full as possible. I always loaded mine and plugged it in to the house the night before. If I loaded into a warm fridge in the morning it would take most of a day to get fully cold in a hot car.
swooshdave
Portland, Oregon
Mustang
I know it's snug, Can you measure up higher (20in or so) because the back seat slopes. Plus to the inside of the back door. Thanks!
redone17
Cold Spring, NY
Even with the backseat fully reclined - it doesn’t sit further back than that lip/edge on the cargo cover which is as far back as you will be able to get the fridge and have it level. Door closing has at least 31”.
Wanderexplore
Andrew
Boulder, co
Lancer gts
Just picked one up and haven't messed with it too much, but doesn't seem like the outlet works without the bronco being on. Is there a 24/7 hot port somewhere?
BroncoAZ
Mitch
This is typical for the cargo area outlet to shut off. In my extensive use living out of a couple different ARB fridges, I can tell you they run best when wired directly to the battery. I rigged the fuse panel in my Subaru Outback and VW Touareg with an add a tap circuit to make the cargo area outlet hot all the time. It worked, but on a hot day the fridge would shut off sometimes because the small wiring showed too much of a voltage loss causing the fridge to shut down to protect the vehicle battery.
Ideally a second battery on an automatic charge relay is the best way to power the fridge. This is the setup that I ran in my Passat TDI for a couple years. It worked flawlessly in Phoenix summers.
Ford Bronco ARB Zero Series Fridge Freezers BD30CB3F-3A4C-4EF4-A1F4-8038181855E1
Stage 3 Motorsports
Stage 3 Motorsports
Joel
Plenty of different options in stock, message me for forum pricing if anyone is interested.
Status
