ARB compressor mount options
Tex
Cliff
San Angelo
Would it be at all reasonable to have the grimm mount in two Broncos and swap the ARB compressor in and out depending on which one is being off-roaded? 😅 I am ordering one grimm for sure after reading this thread - thank you guys for the great info.
Swapping the ARB would probably take more time than installing the mount, unless you also want to buy a second wiring harness, in which case it'd probably take about the same amount of time as the mount. I'm not sure how much time or effort you'd save by getting a second mount over just moving the mount and ARB together...
Nobody
Nobody
Stanwood, WA
www.snowtrek.org
1970 Bronco
Swapping vehicles definitely would not be realistic. Compressors and mounts are expensive, but I consider them essential to off-roading. More so than a winch.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
It would be easier to do this with the KR Off-Road bracket since it's easier to install.
But idealy if you plan to move a compressor between trucks your best bet is a portable kit...
https://www.4x4truckleds.com/arb-twin-high-performance-portable-compressor/
emerald86
Jay
Seattle
69 Bronco, 21 Badlands Bronco, 23 Braptor INBOUND
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Can you buy the kit without the compressor?
You mean just the box? No. It's a complete kit with the compressor and switch and all that already mounted in the box.
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
We offer a bracket that mounts our Twin Air Compressor nicely under the hood. (ARB #3580030)
Ford Bronco ARB compressor mount options 1665445380563
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
ARB portable air compressors are made for this reason!
Ps. we are giving away an ARB Single Portable🤫 Giveaway closes Dec. 24.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Where ya getting that portable single from :) We just went to order more compressors and you guys are out of stock on single portables lol. Can I win that so we have an extra in stock :)
