ARB Awning Mounted
hellahella
Adrian
Nevada
Ford Bronco
I ordered a roof rack but i think 6G would want to know: What roof rack are you using??
grayshadow
Charles
Humble, Texas
I had an ARB awning on my previous rig. one of my favorite mods.
(I still need to lift the right side a bit to make it even)
will deploy this w/e =)
So what are those on top of your cross bars?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Wait, how’d you get those tracks mounted? I’m pretty certain that’s a first. Not exactly low profile - but, what are the weight limit specs?
This thread is about the awning, but that’s the easy part.
I have an ARB Touring too that I’m hoping to mount one day for beach and camping trips.
JGayler911
JGayler911
Jason
Maple Valley
2021 Bronco 2dr Wildtrak
I had Rack Attack install everything. ~300$ - (with warranty)
there's an adapter I have on "back order" - the SmarTSlot kit, that'll make it so the fatcat mounts direct to the bar - gets rid of those giant clamps under the fatcat
Ford Bronco ARB Awning Mounted 1644019156240
static weight limit I believe is ~150lbs, dynamic ~500.
it's not enough to support a roof top tent, but can easily handle a cargo box/basket loaded with gear.
redone17
Cold Spring, NY
There are tents under 150 lbs.
$300 is an inexpensive solution! Looking like they have to drill onto the MIC?
grayshadow
Charles
Humble, Texas
redone17
Cold Spring, NY
Until a full sized adult or two climb into it, unless just the kiddos will be using it.
That’s static weight. Much different and usually 3-4X the dynamic (driving) rating.
JGayler911
JGayler911
Jason
Maple Valley
Hold the phone. What is that rail? Forget your awning lol, what the hell did you do here and how do I do it?
laughed out loud!
cheers brother
Ford Bronco ARB Awning Mounted 1644345553872
hozer
Calgary
Suburban
laughed out loud!
cheers brother
While I appreciate you, you have vastly overestimated my general intelligence.
You do this yourself or have it done.
We're all over here acting like chumps trying to buy roof racks and this mans living in 2037 with his sleek install
