Approach/Proximity Lighting
ChapEJF
Everett
2021 Bronco OBX/BD Mashup
Question for those who have received their Bronco. When you approach your Bronco with the key fob does the exterior lights come on when you are within a few feet of the Bronco?
Mine does not until I unlock it with the key fob or door sensor or use the remote start. I can swear that the lights all around use to come on when I approached it just like my F150. Many thanks,
j_marinelli
Spring Branch, TX.
Mine only comes on when you unlock with FOB or open the door. It is the same on our companies F150 as well.
Rubicon 2 Badlands
San Ramon, CA
2008 JKU Rubicon / 2021 Bronco: Badlands/Sasquatch
Mine comes on when I unlock it with the fob. I’ll look in the settings to see if there are other options.
ChapEJF
ChapEJF
Everett
Thanks for your feedback and I guess I was mistaken.
ChapEJF
ChapEJF
Everett
Thanks so much and I have looked in the settings as well but did not find anything. My F150 had the option to have the lights come on when you approach the vehicle and I must have confused that.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
For those folks who have the proximity lighting or whatever it's called, that would be a good setting to be able to turn on/off. I'd love if my Bronco would turn on this lighting as I approached vs when I go to unlock the door. It's rare I take the fob out of my pocket anymore, but I guess I'll have to if I want this to come up as I walk towards it.
WuNgUn
Ontario Canada
2 door Squatched
This is a thing??
Is the confusion that you thought the 150 did that or that the Bronco did?
First I've ever heard of a Ford doing this without the fob or handle being grabbed
ChapEJF
ChapEJF
Everett
This is a thing??
Apologies for the confusion. My F150 did it for sure. I walked out to my Bronco the other day and thought, why did the lights not illuminate when I got close? Then I tried to remember if they ever did and I could not remember. Now it seems like it is not an option on the Bronco.
WuNgUn
Ontario Canada
2 door Squatched
So it looks like the option on the 150 is called Welcome lighting. Will have to check the FORSCAN thread to see if it can be enabled
