Apple Carplay issues
Indica
Alek
Illinois
ā€˜21 Big Bend
Mine does the same thing with the added bonus of turning off/on constantly in low signal areas. Sync even disconnects my bluetooth in one spot every day. I'm sick of it, but it's on my way to work so I have to deal with it.
Right there with you. Every day on my way to work when service gets spotty, Spotify cuts in and out for a good mile stretch. It makes CarPlay itself lag as well to any touch input I.e. if I try to quickly change it back to Sync and put on Sirius for the time being. Sometimes it crashes entirely, too!
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good afternoon. Would you privately message us with your VIN and the name and location of your preferred Ford dealer so I can look into this CarPlay concern? Thank you!
Indica
Alek
Illinois
ā€˜21 Big Bend
Message sent!
Utahjazzman
BJ
Ram 1500
Can someone explain why carplwy won’t recognize when I plug my iPhone in? It’s like it’s stuck in CarPlay. I don’t even know how to turn it off. I turn off blue tooth and wifi and it’s still connected w/o being plugged in… so frustrating
xusarmy
Todd
TX
2021 Ford Bronco Outer Banks
Over this past weekend 4/21-4/24 I took a several hour drive trying to use CarPlay with my iPhone 10XR. Before this drive, CarPlay worked like a charm, and I usually normally use Pandora and Waze app on all my drives, and I wirelessly charge my phone. On this longer drive, I have found my phone was getting very hot just sitting in the wireless charger and then my phone would disconnect from CarPlay, and eventually reconnect. At this point I thought maybe it had to do with the charging system, so I moved it out of that area, and the problem still happened, with the phone becoming hot and disconnecting from CarPlay. I kind of feel like it could be my phone trying to do too much, but not sure. Just wondering if anyone else has run into this issue? On short trips, no issues, but longer trips, big issue, the playlist thing isn't an issue for me as I dont really deal with playlists.
Jmax
Plymouth
Explorer
I periodically have that issue too but I have experienced it outside of the bronco. Super weird how at times it will get really hot. Completely random. I often close everything down and reboot my phone because that is the first step for all electronics when something is going wrong.
Daktari
Oliver
Mine just stopped connecting to my iphone 12 automatically. I didn't even notice on my daily 2-3 mile drive, just noticed that it stopped switching from Sirius to spotify on my phone while backing down the driveway, which was annoying. Figured it's an update (is there a way to force the stereo to stay on what ever was used last? Which is usually Sirius for me unless I'm on a road trip).
Noticed that car play was gone when I wanted to use Waze, had to connect the phone manually through the menu (or via cable). Service tried to fix it with several kinds of resets, didn't work, so today I'm getting a new APIM installed, we'll see if that helps.
And yes, the wireless charger is not very good unfortunately. I'm hoping that someone will put a kit together with instructions on how to swap it out for something that works. Which is not something I should have to do, but also not something worth going into a back and forth with Ford, it's really only on road trips that I need to charge the phone. Still, I paid for it, it should work....
Jmax
Plymouth
Explorer
Agreed, I love how people will chime in about others complaints about things that don’t work. You hit the nail on the head, they marketed/advertised a feature, we paid for it. It should work as promised but it doesn’t… they should have put a disclaimer like at the end of every pharmaceutical commercial… may… disconnect randomly, over heat, give false playlists, pillars leak, Window pop, roof leak, roof squick, parts may not be tightly fastened, get 13mpg, etc, etc… may drive you to drink literally and figuratively!!!!
Ford Motor Company
Dearborn
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
Jesus Freak
Baton Rouge
2022 Bronco Black Diamond
My 2022 started acting up two weeks ago. Screen goes black, or freezes. Podcasts pause and restart randomly. Phone calls pause and restart randomly. I’ve pushed the volume control and FFD button for 10 seconds with short term success.
I took it into the dealership today and it was diagnosed with having a bad APIM. The part is on back order. This is a very inconvenient issue. Technology, you gotta love it……we’re certainly paying for it.
PartyMarty
Marty
2016 Jeep Wrangler Black Bear, 2009 VW Rabbit
I hate to say it, but I've been waiting for this part since April. There was a month where it worked flawlessly, but over the past month it's been flaking out, and for the past 2 weeks, its been almost entirely dead (press and hold for 10 secs and 20% of the time it'll freeze on the blue bronco, and maybe 5% of the time, the radio will come on (I can adjust the volume, but it's stuck on that station.)
So yeah.... I've been waiting over three months... well past lemon law status...
