Status
Not open for further replies.
Tor148
Tor
Cape May Court House, NJ
23 Braptor Bk, 21 FE RR, 15 F250,
Hey Bronco Fans and Friends- Here is what we have been working on to bring to the Bronco Community...
The Bronco ProRunner Conversion Suspension
  • Long travel Suspension Kit #1: 14.5-inches of wheel travel fitted with 40-inch tires
  • Long travel Suspension Kit #2: 16-inches of wheel travel fitted with 37-inch tires
  • King Race Series coilovers
  • Includes 3.5-inch wider billet upper and boxed lower control arms
  • Wider heavy-duty steering tie rods
  • Raised and reinforced front shock towers with air bump supports
The Bronco ProRunner Conversion Composite Body
  • Hand-laid and vacuum-infused carbon-fiber front and rear fenders
  • An exposed carbon-fender flare edge
  • Three width options are available in ¾-inch, 3-inch, and 5-inch widths
  • A carbon-fiber hood insert with LED marker lights
  • OEM-level fit and finish with improved durability
What Else Is APG Doing To Upgrade The Ultimate Bronco?
  • A full-length one-piece hardtop
  • Additional performance upgrades include a 7-inch wider Ultimate Dana 60TM rear axle
  • Ultimate Dana 44TM front-drive unit
  • 300M HD RCV axles. The Bronco ProRunner package also includes
  • Accessory mounts
Looks great
Question
How are you dealing with the geometry change affecting the cv joints?
Do you drop the front diff?
  • Like
Reactions: APG
APG
APG
George
Garden Grove, California
Looks great
Question
Actually our ride height CV angle is improved over OE, this is accomplished by extending both control arms and not over lifting. We are not allowing the cv angles to pass 33 deg in either direction of travel, as set by RCV. The CV's we use are the best in the industry. RCV Performance
Gritty
Stan
Oak Island, NC 28465
2019 Chevy Colorado ZR2
  • Accessory mounts
Any thing in the works for the 2dr?
Deleted member 32220
Guest
I think it looks good, you just need to be able to build it for under 70k
  • Like
Reactions: APG
SavSqch
Savas
CT
2022 Wildtrak
@Dubsesd Dammmn!!!! Look at that stance !!
Oldirtybastirred
Hoover Alabama
F 150 King Ranch 6” lift
Thanks for the feedback Mike!
There’s always one…or more. Opinions are like, well you get the picture. I think it looks killer. While I don’t crawl with mine, this would be the package to have if you got the cheddar. Great job guys.
  • Like
Reactions: APG
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
I understand an F off when I hear it. Kudos to you for keeping it professional. But really, what’s the point? If it’s a looks thing, ok, everyone has their own taste. Other than that? At a minimum it’s more of a PITA to park, at worst you’re wearing out and putting undue stress on all sorts of parts that weren’t designed to carry the Bronco like that.
Is that kinda stance good for rock crawling like someone mentioned?
There’s probably a whole lot I don’t know. For what it’s worth, I apologize for being a jerk with my comment. 🍻
kodiakisland
Arkansas
If you want long travel on an IFS, you have to go wider. I think of it more for high speed desert running in open spaces. Certainly wouldn't be good for the tight trails around here, but in open areas where you want the most articulation possible, it's the way to go.
RainbowStix
A Big Island
Toyota Tacoma
Will this be using normal spec Bronco King coilovers or a special long travel spec?
specifically,
KRS-25001-392A FRONT ADJUSTABLE
KRS-25001-393A REAR ADJUSTABLE
  • Like
Reactions: APG
CVSJR
Chuck
NJ
'66 Bronco, '09 Z06
  • Accessory mounts
Can you make those fenders fit a Bronco Raptor? I'd be looking for a set or 5-inch wide.
Status
