- Apr 5, 2022
- 39
- 2,179
- 5,461
- Scs michigan
- 22 badlands 2 door. 22 Burban Z71
- Badlands
Will need a mid muffler and then pipe to the back. I fit a 3 gallon in my rear. I’ll walk my lazy ass out to the garage and post some pics for ya.I am planning an extensive onboard air system with tank. The only place I can figure to put the tank safely is where the stock muffler currently sits. This isnt a brodozer or mall crawler. I would like the exhaust to be as tucked away as possible. Would consider an axle dump setup as well. Any ideas for a system that is still relatively quiet and minimal drone? I want to stay married as long as I can.
I went with the awe 0FG. Had the duals on it. Sounded like I had tin cans for mufflers. Took the duals off and put the crawler shorty on. Much deeper tone but not factory quiet. She’s sound a little rowdy upward of 3k rpm. If you stay out of the pedal she’s relatively quiet. Loudest through first and second. Quiet at a cruise on the highway.
Arb dual under the hood on a lifter switch. That runs back to a 3 gallon air tank where the oem muffler was.
That feeds a Arb remote kit next to the hitch that I can run straight 150psi out of it. I have a plug in regulator/separator for controlled air for air tools.
The air tank also feeds the inflate station in the inside rear panel then runs to the 5 port manifold above it. Just set your desired psi. Plug hose in, beeps when it’s done.
I put a manual drain next to the remote kit and ran a hose off that valve under the truck to save on the ears when draining
Then rigged up my inflate/deflate hoses, they go behind the drivers seat for now.
The arb dual on the 3 gallon was enough to install my rear bumper back up lights with a 1 hp grinder. Impact had no issue breaking the lugs loose. Air hammer works, but nothing to test it one yet
I store most the air stuff in the tailgate compartment.
Now you won’t get 100% duty with the air tools but they are useable.
I will be adding a second arb dual shortly next to the air tank. 2 should run tools full time work m guessing.
More info then you asked for but maybe it will give you some creative ideas to post up for others going this route.
I went with this 3 gallon. I almost grabbed a 4 but I didn’t like the port location.
https://www.amazon.com/gp/aw/d/B071PC5VKQ?psc=1&ref=ppx_pop_mob_b_asin_title
https://www.amazon.com/Vixen-Air-Su...uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
