Any Auto Start/Stop Eliminator Problems?
Mscdman
P
Denver
OBX
I’m interested in getting the auto start stop illuminator plug-in for my 23 Outer Banks. The question I have is that the ones on eBay some of the reviews say that it permanently messed up some of the window electronics even after removing the stop start device. Perhaps this is because this is a cheaper version of the one that sold and made in America?
has anyone had any problems with windows or electronics from using his device?
CarmeloS
Carmelo
Central Jersey
Only problems I ever have is when its cold (30s and below), it cycles on and off until it gets to temps
considering its only 3 months of that roughly and 9 months of bliss, not a big deal to me
Mscdman
P
Denver
OBX
What do you mean cycles on and off? What cycles?
BroncoNapped
Bert
2000 S10
Nope, I've had one for about a year now...and no issues
CarmeloS
Carmelo
Central Jersey
a.s.s., in the cold it turns back on and goes back off until its warmed and stays off
again, 3/4’s the year its not an issue, so for half the 1/4, doesnt bother me
LRBTN
Larry
Knoxville, TN
2022 Wildtrak and 2023 Wildtrak
I have the U.S. version on two Broncos for almost two years now with no problems. I also had one on Wranglers with no problems. I have no idea how the eBay version performs but for $100 for the U.S. version why take a chance?
rayhil67
Ray
Douglassville pa
22 2dr Bronco, 06 hummer H3, 01 SuperDuty F250
Bellime
Keith
2022 Ford Bronco
No problems with mine 21K miles
ProStar-Ghost
Sir Slalom
Nebraska
2025 Bronco 2-Door Stroppe
MY23 Wildtrak: floor a/c and floor heat vents don’t work. It is possible they did not work properly before the a.s.s. device was installed. don’t want to pull the lower dash panels out and unplug the device to see if those vents work. the cold will break every clip if I do.
JR23
J
Mass
23’ Bronco
I am running the brand name version (also on a 23 OBX). No issues at all. The price point wasnt so high to make it worth an Ebay flier on a knock off. If you can find a local dealer(which I haven't found by me) to do a ProCal, I'd just put the money toward that.
There is a known "Working as Intended" issue where if you select just Floor on the vent, 95% of the air comes out of the A-pillar vent and the actual floor vents get almost zero air flow.
The workaround is to select Floor + Dash, then manually close the dash vents. This is the only combination where the A-pillar vent isn't used.
That may help with your issue if that's the reason.
Mscdman
P
Denver
OBX
I bought the $99 USA made eliminator. Is that the good one?
whats ProCal? Even though I’ve already ordered my $99 unit.
kpark_67
Aledo, TX
I have NEVER had a problem with mine in the heat or cold.
Mscdman
P
Denver
OBX
For those replying it would be helpful to know your make and model. I have a 23’ OBX
darkscion0
Canada
2021 Badlands Sasquatch
I had this exact thing happen to me and they send me a new device for free that fixed the issue.
