Antenna Mounts for Midland GMRS
WILDcardOD
Patrick
SW Michigan
Rav4, Bronco on the way
Mike T
Brandon SD
2023 Ford Bronco
I used the RCI offroad ditch light brackets. No lights yet but in the future.
Ford Bronco Antenna Mounts for Midland GMRS IMG_2963
RotorOver
Greater Atlanta Area
2023 Bronco Wildtrak, 2021 F-150 Raptor
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
Any recommendations for mounting to your Modular Roof Rack?
Believe it or not, you can mount our TSAM on our TRMR Rack and it works perfectly.
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
Would this mount work for a flag pole for the dunes?
Yes it works for most shorter flags, longer flags use a larger diameter mount which means you would have to bore out the TSAM mount.
WILDcardOD
Patrick
SW Michigan
Ahhhh darn yeah I was gonna put a dune flag on it and they’re like 7-10’
wbrainbow
Bob
New York
1969 C-10, 2022 Black Diamond, 2007 Harley Davidso
It works great.
Ford Bronco Antenna Mounts for Midland GMRS 0C891142-B52E-4D8A-919B-4970BA6B3B1F
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Already had ditch lights mounted using the JCR mount which has extra holes so I mounted my 6db whip antennae right there. Similar set up to @Arlo.Overland but i got rid of the Ghost antennae because it didn't work for a shit for me, the whip antennae is twice as strong, 6 v.s. 3 db.
Same. Ghost antenna had worse reception than my Smiley Antenna Slim Duck. Just ordered the Midland 6db whip antenna. The ghost may be fine for following one another on a trail - but, I lost all RX from local transmissions.
kodiakisland
Arkansas
redone17
Cold Spring, NY
Yeah, I just ordered the MXTA26. That’ll suit my needs.
