Another Happy Mobridge Amp upgrade!
WillinMA
Will
Groton, MA
2021 Wildtrak, 2023 Urban Defender, 2020 Lambo Huracan Spyder
Thanks to Fraser at Mobridge for helping over email/phone in getting my Mobridge AMP working properly! I originally had a Kicker Key 500.1 running a stinger tailgate sub with upgraded speakers all around but still using the factory B&O amp. With the Mobridge I could remove both the factory B&O and Kicker Amp and run everything off the Mobridge amp. And thanks to Fraser for sending me a starting point for a DSP file, I was able to get something close to right without knowing exactly how to do a complete DSP config. So my setup I have focals in the dash and kicks and 6.5 focals in the rear - with the stinger tailgate sub. Mobridge definitely can drive everything no problem and it sounds amazing!!!
Along with taking out the B&O amp, I also took out the sub enclosure and used the MTI amp panel to mount the Mobridge in as well. I had purchased the Mobrodge before they came out with the bronco specific kit - it will make things alot easier between having to run power from the battery (I had already done that for the Kickey Key amp) and then also running speaker wire for the 2 rears and center that are not run off of the factory B&O.
But for a non-pro installer like myself, it all made sense and was relatively easy to do by just understanding the basics.
I was debating between 2 setups...first was the Mobridge amp with DSP - the second was a PAC A2B converter and an Audio Control 6.1200 (and reusing the Kicker KEy for the sub). I 'm psyched with how the Mobridge came out and its definitely a cleaner install with everything in 1 unit!! I'll be putting the Pac A2B and AC amp up on the classifieds if someone wants to try and go down that route as well!!!
silentd74
Craig
Ohio
22 OBX, 20 Edge ST
I can't wait to get the Mobridge Bronco kit with this amp. My separates are all done and I too have a Kicker Key500.1 already installed with an external sub. I want the control of the DSP for the separates and to upgrade my rears to 6.5/6.75. Only thing holding me back is the $$$$ 😆
thenewjs
Archie
Braptor
How did you grab the center and rears?
WillinMA
Will
Groton, MA
You just run speaker wire from the Mobridge amp to their supplied T harness for the headunit in the dash…. Basically use the same factory wiring and connect to 2 of the channels on the Mobridge
mclaffer
napa
Tesla model 3 and Wildtrak
This is a great recap! Thank you. Any pics to share?
WillinMA
Will
Groton, MA
Here’s a pic of the amp in the subwoofer area…. Let me know if there are other pics you are interested in checking out…
Ford Bronco Another Happy Mobridge Amp upgrade! 6I8hmGucQamCA9I58qZa7w
mObridge
Fraser
Orange County, California
BMW e92 328
thenewjs
Archie
Braptor
cve
SW Florida
Taurus
I’m really leaning towards adding this and the JL stealth box in my 2 door OBX
mclaffer
napa
mObridge
Fraser
BMW e92 328
@mObridge will the amp fit into the same location as the factory B&O? I'm looking at the Gearshade 8" box to replace the B&O sub. Would the Mobridge fit in as well?
https://www.gearshade.com/product/bronco-subwoofer-square/
It will mount on the factory subwoofer Box with our mounting bracket that comes in the kit in the 4 door. However if you have the 2 door it will not.
I would say it would likely fit on that box
Read here:
https://www.bronco6g.com/forum/thre...cement-kit-for-b-o-back-in-stock.79680/page-5
mclaffer
napa
Tremendous!! Thank you for the replies!!
