Another DIY tonneau cover
CUZICAN
Lake Charles, LA
2022 Bronco Wildtrak Sasquatch
Like others, I have been disappointed in the available options for tonneau covers, so I finally took it upon myself to make my own. It is made of 5/8 plywood, some square aluminum stock on the underside for rigidity, a little body filler, wrapped in black marine grade vinyl, and held in place by the factory hardtop bolts. Hopefully it'll keep things from walking off when I have the top off.
Ford Bronco Another DIY tonneau cover 20240302_174500
Ford Bronco Another DIY tonneau cover 20240302_174512
Ford Bronco Another DIY tonneau cover 20240302_174423
Ford Bronco Another DIY tonneau cover 20240302_130851
kahunabob
Bob
Santa Clarita, CA
4runner
This is great! I do not know why one of the vendors does not make a plastic/light weight version of this.
Bad_Bronco
Peter
Port Coquitlam, BC
1963 Chevy Nova SS, 2021 Ford Bronco WildTrak
Nice work !!! Can I make a suggestion for easy access, you may want to put a piano hinge on the rear part so that you can lift it up like a lid for more access, and if you have a taller item that you are transporting.
CUZICAN
Lake Charles, LA
I thought this would be a perfect application of the style of ABS bedcovers that undercover makes. It would be light weight and plenty strong.
CUZICAN
Lake Charles, LA
I actually had that thought, but unfortunately the little side wing for the bolts on the rear section hit the roll bar stopping it from folding.
Bad_Bronco
Peter
Port Coquitlam, BC
If you cut a new front piece, and include the two bolts on the rear piece, then you can put a hinge where you have the cut now, and be able to lift and secure from underneath. When I made mine, I used the side as a template and ran it all along the side to the tailgate. Then I made a flat top with hinges, secured under so no one can open it unless truck is unlocked. Hard to see in my pics, but it is strong, and secure when the top is on or off. Also made a top so when I have my fridge in, it is also secure when top off......
Ford Bronco Another DIY tonneau cover 567D5215-7428-45CD-A0D3-3005C2EB0F28
Ford Bronco Another DIY tonneau cover image0 (80)
Ford Bronco Another DIY tonneau cover image3 (36)
broadicustomworks
Hanging Rock, North Carolina
Looks great! I love it when these DIY projects people do turn out nice and finished.
Vinyl is good and taut, curved edges look great. excellent work!
Erica
New York
2021 Bronco 4 door
do any of you DIY'rs whom have designed and made your own hard tonneau covers for the 4 door broncos have measurement/specs? My brother is a fabricator. We are trying to fabricate similiar using fiberglass- so secure/weatherproof. My only problem is I'm not amazing at measuring and he lives 5 hours away. hoping to mock up a template for him. I will post photos and if all turns out, maybe be able to fabricate for others :)
Thank you, in advance. I really appreciate it. I absolutely HATE my vinyl tonneau and with one seat down and the top off, it flaps all over the place.
CUZICAN
Lake Charles, LA
@CUZICAN what pet barrier / metal window grid is this? Can you still recline the rear seats? I looked at a couple like this, but you could not recline.
I'm pretty sure it is the Broaddict one, I can verify when I get home. My seats are reclined all the way, but I did have to make a small mod to make that happen. I just picked up a couple spacers and a couple longer bolts and installed them in the lower hole, causing the panel to sit at an angle. It's still really close and the panel would rattle against the seat on bumps, so I wedge some padding between the seat recline lever and the panel and all is quiet now.
