Am I missing something? Badlands vs Sasquatch option.
Aman
Aman
Northern NJ
Werkedperformance
Philthy
www.instagram.com
Badlands 4dr 7MT
Also, where did you get this info? I would assume they would be getting Squatches out first for rolling advertisements.
From fords official press release yesterday. Late 2021 for manual sasquatch.
Ford Bronco Am I missing something? Badlands vs Sasquatch option. Screenshot_20200922-060844
perfectburrito
Gil
Maryland
23 Badlands Sasquatch, 2.7AT
I just want to make sure I am not missing anything here. But from what I have seen on available sheets and comparisons, the only thing missing from the badlands vs Sasquatch is the 35" wheels and tires.
Does that seem right or is there anything else missing?
In terms of suspension, yeah. There's also aux switches, washout interior, marine vinyl, bash plates and rock rails on the Badlands trim, as well as opening up higher option packages.
Hey19
JJ
Bethlehem
....and with the advent of self driving vehicles, it is only a matter of time until there is a country song about a guys truck leaving him.....
That is hilarious!! Almost blew coffee all over my screen ?
Laminar
Iowa
Cougar
If you're not worried out High or Lux packages, you could get all of that with a BlackSquatch.
perfectburrito
Gil
Maryland
OP was asking about Badlands v. Sasquatch. Obviously, there are tradeoffs compared to other trim levels too.
vrtical
Doug AI
GSMNP, TN
Fords
Sasquatch doesn't have the sway bar disconnect does it?
on the BD and FE yes it does was confirmed with the info that came out with mansquash yesterday.
MIG1963
Michel
Kingston, TN
2012 Mustang
+ Suspension Travel limiter + Wider Fender Flares
Dr.Z
Phoenix
Right there with you. Does anyone feel that badlands wouldn’t be able to handle 35s without a suspension mod ?
because my plan is to go badlands and have the dealer swap to 35s...
Thoughts / issues here?
I figure that’s the best way to get everything
Laminar
Iowa
Cougar
99% you'll be fine. Fender flares are super easy to pop on/off, the aftermarket is going to have plenty of options for sure.
https://www.bronco6g.com/forum/threads/sasquatch-suspension-limiter.3734/
Look for the FAQ screenshot from Ford - Sasquatch just has a longer bump stop to limit travel. If you have rubbing issues you can easily swap out bump stops.
