All models have antenna mounted on mirror base
Bronc-O
Phoenix
2021 Lincoln Aviator
I cannot fathom why a new car in 2021 needs a frigging coat hangar antenna.
3 Reason Pickups Still Have Antennas
Have you ever looked at a pickup truck, realized that they still had a normal antenna and wondered why those still exist on trucks? You don’t see cars, or even crossovers with them anymore, but trucks still do.
Pickups have an antenna, instead of the standard glass build antenna for a couple of reasons. Namely being for design, strength of signal, and ease of repair!
Ford Bronco All models have antenna mounted on mirror base Why-Pickups-Have-Antennas
1. Styling
Most of the vehicles I am sure you think of that lack an antenna tend to be cars. However pickups instead do have the antenna!
Styling plays a big part in this, as trucks tend to be meant to be more muscular, utilitarian and useful. While cars and SUVs tend to be sleeker, more modern, and design conscious.
Because of this difference, it becomes much more acceptable to have older design cues like antennas, plastic cladding, and smaller displays (until recently of course).
2. Pickups are used in rural areas
It’s rather well known that pickups historically have been used as work trucks, and work trucks tend to be used more regularly in rural areas.
Meanwhile, cars tend to be more used in cities.
Because of this difference in areas, trucks have tended to need more intense antennas that will allow weaker radio signals to still be able to be utilized by the truck.
The bigger an antenna is, the more signal it can pull in! Hence the larger antenna on trucks.
3. Easier to fix if damaged – easier than glass antenna
Alternative versions of antennas outside of your standard one we are discussing in this article are much more difficult to replace than older versions.
Normal tall antennas are really easy to replace, as it is just the antenna attached to a ball at the bottom. This is something anyone could replace if they wanted to.
Meanwhile on most cars, antennas are either attached to a windshield, or are underneath some plastic bodywork, well beyond what most people would be willing to repair.
When you have a work truck, you want to be able to fix things cheaply, and inexpensively. The older style of antenna thankfully still offers that ability.
chipbutty
Ontario
Nothing cool
1. Styling
Ill buy #3 that makes sense for an OR vehicle. Appreciate the info, thanks!
BAUS67
redneck
Central PA
Because some of us still listen to the radio. :D
I can't understand why people want IFS in an OFF ROAD vehicle. :ROFLMAO:
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
Because some us like to throw chairs.
I can't fathom why they can't believe it's not butter.
Haulin' Auss
Shawn
2016 Ram 2500
The real question is where is the satellite radio antenna?!?!
Straight 6
Brad
Ca
BMW
Look at the open top pictures, it's a small puck on top of the rear roll bar and under the roof
And sidenote, the whip antenna is pretty crappy looking. But with the removable top it's not like they could have put it on the back glass or rear side glass as is typical. I don't think the front windshield is where that in glass antenna usually goes.
xXChartmanXx
Ford Explorer, Honda Pilot
1. Styling
My guess for the Bronco, the biggest reason is that normal window antennas are in the rear or rear side window in cars and SUV's. Being as they are removable or plastic as are the doors and their windows, not really an option for a Bronco.
