Alignment Specs?
Slick85
Richard
Austin, TX
So I took my Bronco to get alignment at NTB (I had purchased a 5 year plan with them on previous vehicle) and they said Ford still hasn't sent them the alignment specs for the Bronco. They were able to improve it so it doesn't pull to the side, but should I take it to an off-road specific shop? Note that I have a 2" life and 35s but the place I got it lifted at is about an hour away. Thanks
flip
Phil
IN
www.ruxerparts.com
Fords
Specifications
General Specifications
NOTE:
Measurements listed at curb load. Curb load is defined as full service fluids, full fuel tank(s), no passengers and no cargo.
Item​
Specification​
Ball Joint Deflection (All Vehicles)
Upper Arm Ball Joint​
0 - 0.2 mm (0-0.008 in)​
Lower Arm Ball Joint​
0 - 0.8 mm (0-0.031 in)​
Side-to-Side Lean (All Vehicles)
Front — maximum​
8 mm (0.314 in)​
Rear — maximum​
8 mm (0.314 in)​
Front Ride Height
BASE, MID - BIG BEND, PREMIUM - OUTER BANKS, WILDTRACK, BLACK DIAMOND SERIES vehicles​
96.0 mm (3.779 in) ± 12 mm (0.472 in)​
BADLANDS SERIES vehicles​
113.0 mm (4.448 in) ± 12 mm (0.472 in)​
ADRENALINE RUSH PACKAGE - HERITAGE STANDARD, OVERLAND, WILDTRACK UPGRADE SERIES vehicles​
122.0 mm (4.803 in) ± 12 mm (0.472 in)​
Rear Ride Height
LH​
RH​
85.0 mm (3.346 in) ± 12 mm (0.472 in)​
247.0 mm (9.724 in) ± 12 mm (0.472 in)​
102.0 mm (4.015 in) ± 12 mm (0.472 in)​
265.0 mm (10.433 in) ± 12 mm (0.472 in)​
115.0 mm (4.527 in) ± 12 mm (0.472 in)​
278.0 mm (10.944 in) ± 12 mm (0.472 in)​
Alignment Specifications
NOTE:
Item​
LH RHTotal / Split
FRONT SUSPENSION
CASTER - BASE, MID - BIG BEND, PREMIUM - OUTER BANKS, WILDTRACK, BLACK DIAMOND SERIES vehicles3.47° ± 0.60°3.47° ± 0.60°0.0° ± 0.70°
CASTER - BADLANDS SERIES vehicles3.35° ± 0.60°3.35° ± 0.60°0.0° ± 0.70°
CASTER - ADRENALINE RUSH PACKAGE - HERITAGE STANDARD, OVERLAND, WILDTRACK UPGRADE SERIES vehicles3.18° ± 0.60°3.18° ± 0.60°0.0° ± 0.70°
CAMBER - BASE, MID - BIG BEND, PREMIUM - OUTER BANKS, WILDTRACK, BLACK DIAMOND SERIES vehicles-0.23° ± 0.50°-0.23° ± 0.50°0.0° ± 0.70°
CAMBER - BADLANDS SERIES vehicles0.12° ± 0.50°0.12° ± 0.50°0.0° ± 0.70°
CAMBER - ADRENALINE RUSH PACKAGE - HERITAGE STANDARD, OVERLAND, WILDTRACK UPGRADE SERIES vehicles0.20° ± 0.50°0.20° ± 0.50°0.0° ± 0.70°
Toe - (positive value is toe in, negative value is toe out) - All Vehicles0.20° ± 0.20°
REAR SUSPENSION (Audit specifications - For reference purposes only)
CAMBER - All Vehicles0.00° ± 0.75°0.00° ± 0.75°
Toe - (positive value is toe in, negative value is toe out) - All Vehicles0.22° ± 0.20°
Thrust Angle0.00° ± 0.50°
© Copyright 2023, Ford Motor Company.
PWillette
Parrie
Maine
Specifications
NOTE:
Item​
Specification​
Front — maximum​
8 mm (0.314 in)​
Rear — maximum​
8 mm (0.314 in)​
Front Ride Height
Rear Ride Height
LH​
RH​
NOTE:
Item​
LHRHTotal / Split
FRONT SUSPENSION
Interesting ride height dimensions with WT being grouped in w/ base, BB, BD and OB and less than BL ride height.
Not sure what the "Adrenaline Rush" package is but sounds cool.
flip
Phil
IN
www.ruxerparts.com
Fords
SAS
