Additional Sound Deadening (High Package component) - What/Where is it?
Spotter
Sam
Walnut Creek, CA
Honda
I am very curious about this as well. Wondering if it's all stuff that can be done after market, or if we can only get it in the high package. I definitely would want sound deadening, but the High package isn't offered on the BD, which I currently have reserved.
Ride Em Bronco
Al
Pittsburgh, PA
2024 2-door 6-Speed Manual Big Bend Bronco
Option for the B D:
Hard Top Sound Deadening Headliner (requires Hard Top or Dual Tops)
Paint
Jack
Oklahoma
Tundra
Y'all have this stuff backwards. See...The way this stuff works is...
Then when your mud terrains start howling and the wind starts slamming the sides of your head...
...You can no longer hear your spouse.
BOOM. Sound. Deadened.
Valhalla_Overland
Charlotte, NC
2019 Toyota Tacoma DCSB OR
After doing all the sound deadening in my Tacoma, I can definitely say I'd just rather have it installed from the factory. I doubt it would add more than 30 lbs to the roof overall, depending on how much they use.
Karl_in_Chicago
Karl
Chicago
Really not enough info at this point. For point of comparison this is one of the more popular after-market headliner add-on's for Jeep Wranglers - and most agree it's better than the available Jeep factory applied option. It's still pretty basic - I'd hope with all the research and design work Ford has clearly invested in this new Bronco they have something even better, but it's the kind of thing I'd want to see more of before committing to.
https://hotheadheadliners.com/
Felix808
SRV CA
Sound deadening can always be done aftermarket.
Wanted33
Down south in Dixie
I bought the Hot Head liner for my Jeep. Much better than factory, and cheaper. I would guess the kit for the 4 door was around 10 pounds, and really helped with the heat also.
Zinn
Minnesota
2016 Mustang GT, 2020 Ranger Lariat
This is not the hard top headliner. The hard top headliner is a separate option.
The “High” package lists “Additional sound deadening” as a bullet feature (which wouldn’t even make sense on a soft top 4 door). So I think the question stands. What is this? Do they spray some insulating foam inside the door panels?
2Jeeps&PatriotX1
Denver, CO
I used sound deadener in my soft top jeep and it does make a difference. I did it after tucking the transmission up closer to the tub for ground clearance and skid plates. Like the poster above mentioned, Id pay the factory to do it before doing it again, it was a process (removed everything down to the tub, door panels and firewall.
I havent found enough info yet to determine what ford classifies as sound deadening in the bronco.
