Additional Sound Deadening (High Package component) - What/Where is it?
WuNgUn
Ontario Canada
2 door Squatched
It IS in the body! Nothing to do with the roof sound deadening. It's added on the production line.
Ford Titanium models (and older SES) get extra sound deadening.
My 2011 Fiesta had it... Somewhere.
Probably a few extra adhesive mats stuck to exterior panels (doors) and extra matting over the wheel wells and footwells.
Sergio El Bailador
Arthur
Mustang
Hard Top Sound Deadening Headliner (requires Hard Top or Dual Tops)
The conditional requirement for a hard top suggests it has at least something to do with the roof. My personal guess is it's a simple headliner like the one OEM option for Wranglers.
https://www.moparonlineparts.com/sku/82212464ac.html
Bronc-O
Phoenix
2021 Lincoln Aviator
Bdisco
Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
‘88 911,‘15 Chevy 2500, ‘24 Acura Integra Type S
I’m guessing if it‘s like Jeep’s it’s more like the stick on dynamat they put on the Freedom panels roof sections.
The head liner kept sagging in my 1981 F100 so I just ripped it out and exposed the nice painted underside of the roof. If you got caught in a sudden rainstorm it was like being inside a drum.
Wasatch
TD
SoCal
JeepJK
Knowing about sound deadening would be great. I have a Jeep JK with an aftermarket hardtop that is fully carpet lined. This was big improvement over OEM soft top. But when I put roof rack on the wind noise inside of cab was almost as bad as soft top. I really learned my lesson here and will not be putting a rack on the 4 door I reserved. If it doesn't fit inside it satys home.
2Jeeps&PatriotX1
Denver, CO
Some of the videos seem to suggest it's in the body. Likely something like Dynamat under the carpet.
Which is what I did to my jeep but then I also added closed cell foam layer and them mass loaded vinyl on top before reinstalling my carpet, dash and door panels.
edgeflyer
2013 FX4
Y'all have this stuff backwards. See...The way this stuff works is...
Then when your mud terrains start howling and the wind starts slamming the sides of your head...
...You can no longer hear your spouse.
BOOM. Sound. Deadened.
I was really hoping it was between the front and rear seats to block out the kids. Still hopeful.
Wanted33
Down south in Dixie
This is not the hard top headliner. The hard top headliner is a separate option.
The “High” package lists “Additional sound deadening” as a bullet feature (which wouldn’t even make sense on a soft top 4 door). So I think the question stands. What is this? Do they spray some insulating foam inside the door panels?
I'm thinking you're correct Jeff. It wouldn't make sense to offer the headliner as an option on the soft top versions. It may turn out to be a very good option for the Bronco's with the "squatch" package, or maybe even depending on the amount of road noise in the non "squatch" ones.
Joe Dirt
north carolina
tundra 2001
I have watched many videos and want nothing to do with after market sound deadening install. I just hope it is extensive with the Badlands/sasquatch upgrade.
96ExplorerSport
96ExplorerSport
White Plains NY
1996 Explorer Sport
This is a killer. I wish the "additional sound deadening" were available a la carte and didn't require the High Package.
