- Richard
- Jul 3, 2021
- 9
- 557
- 1,529
- Bakersfield
- '22 Badlands 2 dr 2.3L, 2000 Ford F450 PU, 2001 Jeep Cherokee
- Badlands
Thanks for sharing!
I'm just noticing this thread as I contemplate a base with switches over my anticipated BaseManSquatch. I plan on having onboard air and consider front and rear lockers essential for what I plan to do and to help compensate for lack of sta-bar disco (until after market solves) when it comes to lifting wires.
I recently attended the Off-Roadeo in Nevada and while the e-lockers worked phenomenally well I ended up with an ABS sensor issue that led to disabled front locker and sta-bar disco towards the end of the day. They explained the vehicles had only been used for off-road use for extended periods every day with little to no on-road driving which can supposedly cause issues with the sensor.
Nonetheless it does make me reconsider the base with air lockers route, at that I'd just be losing the 210 which, similar to @goatman, I'm just not sure I even need, and the 4.7 gearing which I would prefer off-road but would also enjoy the slightly better fuel economy on-road with the 4.46.
I could perhaps see 37s in the future but doubtful I'd go bigger. Hoping the updated B&P helps push me further to either side – I just want to drive my damn bronco.
Well, since you mentioned me, I absolutely won't buy a Bronco without the M210 front end. I want the steel M210, and not the aluminum M190. I am going back and forth between a basesquatch and a Badlands without Sasquatch. Recently I priced out getting a base base and adding gears and lockers, compared to getting a Sasquatch or Badlands, and it did not pencil out. I calculated using the price for a complete M210 center section which comes with gears and the locker. We don't know yet how reliable it is to run 37's on the M190 front end, but there is a reason that Ford went with the M210 when using 35's.
BTW, at the Nevada Off Roadeo, we talked about the sensor problem. When that has happened they told me all they did to fix it was to drive it out on the highway and it all reset. No repairs had been done yet. Also, if it's a chronic problem, Ford is very likely to come out with a fix for it.
ARB lockers have their share of problems as well. The harness that comes with the lockers won't let you turn on the front locker unless the rear locker is already turned on, something Ford specifically did not do because of input from real off roaders. ARB solenoids are prone to go out, most people with ARB's (that know to do it) carry spare solenoids. The air seals inside the diff carrier also can go out. This isn't as big a problem as it used to be, after ARB redesigned the seals a number of years ago, but it still happens. I guess what I'm saying is that if reliability is a big concern for you, I'm not sure ARB air lockers would get you what you want.
Lots of things to consider here. Don't know the right answer. I've decided I'm going with factory gears and lockers.
