Adding hanger
mla
Oregon
'24 Bronco Heritage 2dr
I know there's a lot of molle solutions for storage and such, but is there a simple solution for just having a hook or two? Need something to hang dry cleaning from.
Was looking at these but they seem pretty expensive for what they are and can prob DIY it with the right bolt size?
https://www.amazon.com/dp/B0BKZMSL5N?ref=ppx_yo2ov_dt_b_product_details&th=1
Suggestions?
Ford Bronco Adding hanger hook
Thanks.
WheresMyBronco
Los Angeles
2023 Badlands
Where are you looking to install it? Personally I think the best option for that would be to utilize the bolts in the roll cage above the passengers, so maybe figure out what size their threads are and replace them with a hook? I think they might be M6 x 1.0
  • Like
Reactions: mla
mla
Oregon
I wasn't sure and I'm new to my Bronco so not sure what is best. Roll cage sounds like it could be good. Will take a look.
Neverowneda4x4
Do you plan to get grab handles? I got the Paracord ones and I hang my dry cleaning from them. It twists the handles a bit and thr clothing sits at a bit of an angle but that can even be resolved with a carabiner.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
I use these. Anything else is too low.
Ford Bronco Adding hanger 20240327_134121
  • Like
Reactions: mla
mla
Oregon
Was just looking at those. That could be a nice twofer. Who did you go with for that?
Neverowneda4x4
I went with seven Sparta on Amazon. They had the matching beautiful yellow color for the badlands trim.
  • Like
Reactions: mla
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
  • Like
Reactions: mla
helifino16
Ron
Mount Sinai, NY (Long Island)
Do you plan to get grab handles? I got the Paracord ones and I hang my dry cleaning from them. It twists the handles a bit and the clothing sits at a bit of an angle but that can even be resolved with a carabiner.
Same here, but with the 2-door, it blocks the window (lol). I picked these up on Amazon a while back. They mount on the roll bar in back. Too low for clothes, but still very handy.
Neverowneda4x4
Not bad. I've seen similar ones a while back from a different manufacturer for like $40 (no way!). I got D rings for those locations instead, and use a carabiner to hang stuff from it.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
  • Like
Reactions: mla
mla
Oregon
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
I like the simplicity. So d-rings with a hole that accommodates the ... what is it m8 bolts?
Something like this?
https://www.amazon.com/Diameter-Cargo-Tie-Down-Replacement-Warehouses/dp/B01CGXSNC0/?th=1
Yes, M8 x 1.25mm thread pitch. The item you linked has a 10mm hole for mounting. It should work fine. May rattle when not under load. You may want a plastic or rubber washer behind it to protect the paint on the bar. The rings I use have no moving parts.
Ford Bronco Adding hanger 1712338186061-i
  • Like
Reactions: mla
