Adding a 12" Swing-Gate Sub- Questions regarding install
CV428
2023 Bronco OBX, 1969 Mustang Mach 1 428CJ
I had a sub-delete '23, so I spent the weekend installing Kicker speakers all around, upgraded the rear pods, Plug-N-Play 200.4 and a 500.1 with a 6.75" sub in the enclosure. I also did SecondSkin soundproofing. The sound difference was amazing. It went from being the worst sounding audio in any vehicle I have owned to the absolute best by a wide margin.
That little 6.75 sub sounds great but it is missing sub-50hz presence. I'd like to add a 12" sub to the swing gate. I already have 6ga to a distribution block at the side sub enclosure so install should be a breeze.
My question is, if I make a splitter from the 4 signal wires to the 500.1 so I can run them to the other amp, would that be an issue? I'd like to find the 4-wire square connector- looks like a universal connector from AAW.
