Adaptive cruise and crash front sensor removal
DubaiRaptor
United Arab Emirates
bronco
Hi all.
this is my first post of many on my Bronco Raptor ownership and modification.
First thing I would like to ask is that my Raptor came with the adaptive cruise and so it came with the front sensor but I want to remove it to allow more air into the intercooler and I don’t want to relocate it,
Can you change the coding with forscan to disable/ remove the option?
thanks
Motovita
WA/AZ
25 Bronco
Hi all.
thanks
On my badlands I can turn off adaptive cruise without forscan, you probably can too.
Motovita
WA/AZ
25 Bronco
Hi.
yes I can but it’s more I want to remove the sensor to allow more cold air to the intercooler.
What happens if you remove the sensor with it turned off?
DubaiRaptor
bronco
I haven’t done anything yet. I was first asking questions. Also I don’t want errors showing up.
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
What year is your Bronco?
Edit: Never mind.....I don't think the year matters on these trucks. I'll see what I can find.
rugedraw
Javier
Miami, FL
I think you would need to disable ACC and TJA here in the IPMA:
Ford Bronco Adaptive cruise and crash front sensor removal 1780426201239-5k
There is no info in the Bronco or Raptor spreadsheet for the CCM, but I think disabling ACC in the IPMA would be enough. There are also settings for IACC in the IPMA that may need to be disabled if disabling ACC alone is not enough:
Ford Bronco Adaptive cruise and crash front sensor removal 1780426992628-n5
I can't find anything in the IPMA or IPMA regarding front parking sensors. All I can find in the APIM are these bits below. I am not sure if disabling these would prevent any codes once you actually unplug the sensors, but hopefully this helps.
Ford Bronco Adaptive cruise and crash front sensor removal 1780426799416-hj
Ford Bronco Adaptive cruise and crash front sensor removal 1780426821209-h7
rugedraw
Javier
Miami, FL
Oh, and you may also have to dig through this section of the ABS to disable cruise control with ACC. If you disable it in the IPMA only, you may have some incompatible config codes if it is not also disabled in the ABS.
Ford Bronco Adaptive cruise and crash front sensor removal 1780428716672-0v
DubaiRaptor
bronco
Hey guys.
finally going to attack this at the weekend.
but I’m very nervous. Can anyone give me the numbers to change to and in which modules.
Thankyou.
