Actual Tire Height
flatlander40
I read the bronco nation article on understanding tire sizes. I am no math guy I make lots of mistakes, so somebody needs to check me LOL. If the results are correct I thought it was kind of interesting.
Tire height
Black diamond
is 31 39/64” tall
Big Bend is 32 1/16” tall
29/64” taller than the BD
Badlands is 32 45/64” tall
21/32” taller than the BB
kodiakisland
Arkansas
I think the 31.6in Generals may have been discussed in a thread or two.
BroncBro
2019 Tacoma 4x4
Tire height
Black diamond
is 31 39/64” tall
There’s no math involved. Just go to the tire manufacturers website. They list their actual size. All manufacturers vary between other brands and other tire types. They’re all slightly different.
Lcubed
l
UsA
VW golf r, 2023 ManBadSquatch
It depends on whether the tire is at the normal pressure for road use. If you’re aired down for trail use,lower your expectations. Of course, if it’s an E load range tire, the side walls are stiff enough that the ride height may not change significantly.
BroncBro
2019 Tacoma 4x4
Thats cool, but not what the OP or anyone else was talking about.
flatlander40
Okay ??
I looked at a few of them and was just seeing the numbers on the tire but thanks
I thought it was interesting that the Heights on all of them aren’t much different. So I understand some are light truck and different treads and what not. I’m probably looking at a lower trim but I didn’t want it to look like a skateboard LOL
honestly it’s time to just have some more real examples out there to look at.
HoosierDaddy
__ Eric
NW. Indiana
Tirerack.com is one of my favorite resources for comparing tires by brand and model, because as noted a 33" inch AT may be a few tenths different than a 33" MT even for the same manufacturer.
If I am getting into the nitty gritty of gear ratios, I use the manufacturers Revolutions per Mile numbers and my favorite calculator for gearing and tire comparos is : http://www.grimmjeeper.com/gears.html
and then there is this site which basically lists all of the sizes but the information is pretty general in nature, nothing super specific ..... https://tiresize.com/tiresizes/
Nickp
Nick
Phoenix
Just in general tires run about 1/2 an inch smaller than their stated diameter. A 315/70r/17 is really about 34.5”, a 285/70r/17 is usually about 32.5” etc. now this depends on brand, some are closer than others. But just in general tires always run a bit small.
flatlander40
Awesome!! Thanks for the resources!
HoosierDaddy
__ Eric
NW. Indiana
That concept baffles a lot of folks.... especially when they move from a metric to a stated tire size, 35 x 12.5 .... and dicover they actually went down in size.
I saw that a few times at the Ford Tremor forum... factory metcric size is 35.1" tall.
I want to say Nitto and Interco build them to stated specs.....a 35 is by golly 35", when mounted and aired up.
North7
North Texas
SUV
I always use tiresize.com, it's easier to see more tires there vs tirerack.com. What am I missing, same information at both sites on the Badlands 33" KO2 tire example below. In fact, tiresize.com lists Max Speed and tirerack.com does not. :unsure:
https://tiresize.com/tires/BFGoodrich/All-Terrain-TA-KO2-285-70R17.htm
Ford Bronco Actual Tire Height 1599329798893
Ford Bronco Actual Tire Height 1599330075946
HoosierDaddy
__ Eric
NW. Indiana
WOW, thanks for pointing that out!
Not sure how I missed that before, although, I only found that site recently and hadn't really dug around it too much yet.
You know, you get stuck in a rut going to the same place all the time....
I was only using the lists that would show what sizes were available for , say ... a 34" tire in 17 or 18 inch wheels...that is a real handy tool.
LOL, I think I have a new favorite!
