A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades
Panzer948
Panzer948
Charlotte, NC
www.youtube.com
1981 CJ5, 2015 BMW M4, 2023 Mach E GT PE
They fit fine in the dash. I put Focal ACX in the pods because I read the C1s don’t quite fit. C1 in front and Focal in rear is a great combination.
Yes, this is basically true. No problems fitting them in the front dash at all. Not sure why they say that... For the rear pods it is a very tight fit. I got mine in but the tweeters do push slightly on the grill. You can see it bulge out slightly but other than that I say they fit. I am probably the only one that notices it.
ColeTrain84
Cole
Minnesota
'22 Bronco Badlands
Is there bolts in the top part of the center cover back by the mounting bolt? Or the mounting bolt itself needing to come out?
Snowdogyyz
23 Ford Bronco Wildtrak
There are 2 bolts on each side of the accessory mounting hole. Once those are out, you can pop the cover off but be careful with the USB cable/plug.
Kai
Allen
Toyota Rav4EV
What size though? Impossible to see in there
Kai
Allen
Toyota Rav4EV
Torx t27 btw
JustmeGee
Gerald
NYC/NEPA
2022 Bronco Outer Banks
For the life of me i can not get those screws out
I have tried every size Torx
Its almost impossible to see in there
So frustrated
Is there any way around it?
Eldo21
Chad
Vail, CO
Tesla M3P, Jeep JLUR
I was just going to add… wtf ford, why use a torx in that spot? Another 7m bolt would have been so much better.
LiftedPony
Sean
Irvine, CA
2021 Wildtrak 4dr, Porsche GT4, Porsche Macan GTS
So frustrated
Came right out with T20 Torx
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImageFLDPyv
LiftedPony
Sean
Irvine, CA
Here is a quick guide to removing the center dash speaker cover for the B&O system:
1. Remove the "Accessory Ready" stand with Torx T-20
2. Start prying with prying tool from the outer top edges gently until clamp comes out
3. Pry the side closest to the accessory ready area from the sides until they lift up but isn't fully out
4. Push the USB charger inwards towards yourself, then lift it to snap out.
5. Repeat same process in reverse to install again
FYI I have an extra JL Audio C1-400X speaker brand new in box from the two pairs I bought from Crutchfield (Only needed 3). $50 shipped lower 48 states
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImageHpl01M
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImageFPmad2
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImageqhLmRS
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImageeCJywD
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImagetOSus
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImage1i7ca8
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImageXZToMN
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImagesZxEXv
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades tempImageufINhV
  • Like
Reactions: Biz
LiftedPony
Sean
Irvine, CA
Anyone still got an extra dash speaker to sell?
I got a brand new pair of ACX 100 4" that never have been installed for either the front dash or rear pods that you can use if you are interested.
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades IMG_7372
Pdshepherd
Patrick
Gulf Breeze, FL
None. Wife's Kia is my part time wheels
Thanks. Will let you know. Have a deal cooking but if fails will advise. 👍🏼
Biz
Biz
Canada
21 OBX 2dr / 2019 Edge St / 2016 Focus RS
Big thanks.
This information was very helpful.
we were stuck.
Ford Bronco A Solution to Replace the "third" B&O Ctr Dash Speaker with 3 Matching Upgrades 7CF9FCC4-A739-410E-A131-3D79B92B09B5
Sammy O
Sammy
Alabama
2013 F150 STX, 2023 Eruption Green OBX
Did you have any clearance issues with the grille when you put it back on? I see where Crutchfield says this speaker won't work in the dash corners due to height. Any issue there with grille? Still got the single speaker?
Thanks!
LiftedPony
Sean
Irvine, CA
Thanks!
No clearance issue, you just need to plug in the speaker to the adapter first, tuck the adapter in, and then twist the speaker from side to side until the clears the plastic edges to sit flush and screw down. No issue with new speaker touching the cover either after install.
omi205
BoJack
Austin
I was reading that changing the speakers dont make a huge difference unless the amp is upgraded also? Are you guys doing both or finding good results just doing the speakers?
