A-Pillar/Ditch Light Kit
Dragline
GMC Yukon Denali, GMC Sierra 1500, Honda Civic, Chevy C3500
Were covers not included? First pic shows covers on the lights, there's none in my kit.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Hossamus Prime
Arkansas
www.instagram.com
21 BadSquatch,‘21 ExplorerST , RIP 84 & 90 Broncos
When people are wiring their a-pillar lights to the Aux switches, are you wiring both to the same AUX switch? or RH on one, LH on the other?
Bronco21fan
Angelo
NewJersey
I’d imagine both to the same switch that way your
Not wasting a switch
SpeedTwin
Ethan
Missouri
F250, Mustang, WRX
I put mine on the same switch. I have plans for the other switches for other accessories.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Both to the same switch, as the harnesses included with these kits only allows for that type of configuration. Otherwise you'd need to run an independent harness to each light. I've never seen anybody wire the left/right up separate but you could if you wanted to aim them off to the ditch and control them separately.
Hossamus Prime
Arkansas
www.instagram.com
Thanks, thats what I assumed. Figured id ask before i got too deep into the install.
Hossamus Prime
Arkansas
www.instagram.com
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
the 2 clasps here is what got me thinking
The white wire goes to your upfitter. The green wire is the "low" power mode (I assume you got the XL Sport/Pro/80). It'll active the lights in a LOW mode when positive power is ALSO applied to the green wire. 99.999999% of our customers don't bother with the green wire, as who's going to need low mode (as that's still too bright for public roads on pillars)
Hossamus Prime
Arkansas
www.instagram.com
XL80s, thank you sooo much. A1 customer service sir!
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Tennman
Tennessee
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Is the coupon code in your sig still active? I tried to use it but maybe its not available on the items I'm trying to purchase.
The coupon code in our signature isn't valid on all items. Certain manufacturers prohibit the use of coupon codes.
Hossamus Prime
Arkansas
www.instagram.com
Happy to help
Got the XL80S installed today. Boy those suckers are bright, got a tan trying position them. Lol I love them!! The upfitter harness made it so easy!
Ford Bronco A-Pillar/Ditch Light Kit EEB4AD29-2925-4EA4-92CC-E39E9C77B5B1
Ford Bronco A-Pillar/Ditch Light Kit AFEF3207-2815-44F8-B3F4-FD1046AA48DC
Ford Bronco A-Pillar/Ditch Light Kit C43D84B0-A8A7-4987-8158-65165D1E6C34
Needs a little adjustment, not much
