SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
So, about a month ago I was given the opportunity (by Daniela@3wLife) to test out 2 of the most popular Fridge sizes from Wolfbox (19QT & 39QT). I decided to take my time and "live" with them for a little bit so I could do a proper side-by-side comparison. They have a pretty extensive selection - 19, 26, 39, 48, 49, 58, 59 Quart versions. Since the 48/49 & 58/59 ones seemed too oddly similar, I opted to test out ones farther away from each other in the spectrum.
SIZE/CAPACITY:
I wont' get into the all the specs of each one (as some others here have already), but focus on "livability and usage." Right off the bat - the 19QT is actually the perfect size for the rear compartment of the Bronco if you desire more available space. I have it for permanent usage and don't plan to remove it (I have it tied down with straps). It's just enough space for one to have a few cold beverages on hand anytime, or a nice chilly sandwich(s). I live in Las Vegas so the average temps during the summer make this a welcome addition to my Bronco :) Although note that I am from a single household and am usually always alone when I drive so this is perfect for my needs. I also do NOT need anything frozen 99% of the time, even when I go off-roading or camping. IF you are a couple or have kids, the 39QT would be the way to go. Yes, it is a little bigger but you will still have space back there for other stuff. You also get separate doors - one for the Freezer and one for the Chiller side. A LOT of space for ice cream, frozen steaks, drinks and fresh produce. Here are some "SIZE" pics to compare:
39QT:
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7783
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7784
19QT:
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7785
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7786
SIDE BY SIDE:
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7787
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7790
"Capacity" shots:
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7794
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7795
BOTH in the trunk (I do this for Soccer Practice and bring the 39QT for all the kids):
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7799
BEHIND that 39QT Fridge is my 10-inch subwoofer enclosure (also to give you perspective of space):
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7798
USAGE/UTILITY:
I've found that the best practice is to set the Fridges to desired TEMP(s) at home, plugged in. Then transfer to vehicle, power via DC cigarette-plug. When I get to Soccer Practice I connect to my Bluetti Power bank. Works great and maintains enough of its temps throughout the 2.5 hours in 90 degree heat (no sun). Keep in mind that the kids are CONSTANTLY opening and closing this so there is cold-temp loss for sure, but the Unit (39QT) manages to maintain enough to keep drinks chilly and the ice cream from melting. As mentioned earlier, it has individual doors for Freezer/Fridge as well. To help maintain the cooling effect, I sometimes add a "Freez-Pak" to the freezer section. One of the big differences I noticed, that likely affected maintaining temps, was that the ENTIRE inner-container on the 39QT is solid plastic, compared to the 19Qt that only has a plastic base and has seams on the upper, aluminum lining. Left overnight in my 90 degree garage, unplugged, the 39 QT kept it the drinks cool to the touch in the am, while the 19QT bottles were a tad higher than room temp. ALSO - the 39QT has wheels and a large, comfortable handle that makes transport through a grassy field a MUST. I mean, if you are going to be transporting this out of the vehicle in any way at all.....the wheels are very convenient and a necessity for the 39QT size and above.
A HUGE benefit for me is the Bluetooth Connectivity that allows you to monitor temps and control battery drain. Very nifty and SUPER handy! I actually have my fridge plugged in once I park in the garage, and leave it that way....Kinda like having an electric vehicle...But with terrible fuel mileage. Hahahaha!!! :cwl: But - I can easily monitor it from inside my home and adjust it accordingly if need be. I'll keep it at a steady 20 F while parked, so when I leave it's always chilled. Once it hits the target-temp you set it at, the compressor turns off and only comes back on after a +3 degree change. When parked you can adjust the "level" of battery-voltage sensitivity (low, med, high). Because after you turn off the ignition it continues to stay on and will turn off at the point you set it at. Great energy saver and makes sure you don't DRAIN your battery and can't start your Bronco.
They also both run surprisingly QUIET and do NOT emit a lot of heat. Another thing to note is the cover/latches on each one. The 19QT has a single lid (that opens BOTH ways) and the latch is a mechanism you have to pull horizontally (left or right) to open the lid. The 39QT has individual lids and REALLY nice latches, easier to open as they move vertically which is a more natural hand movement. I wish the 19QT had the same latches.
So far they have both been performing great and I'm looking forward to seeing how the long-term performance is. Great product!! I highly recommend it! Here is a link to it if you all need more info - https://wolfbox.com/?ref=qpqddyio. Some more pics below:
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7801
Ford Bronco Wolfbox Fridge / Cooler - 19QT vs. 39QT Review :) IMG_7818
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
I just got the 25qt version - so far so good.
Tricky Mike
21 Bronco
They look pretty rugged. I was thinking of the Iceco APL35 for my next fridge though.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
ICECO's are sweet man, especially with the optional magnetic battery :) Although more than double and no wheels for hauling around.
vrtical
Doug AI
GSMNP, TN
Fords
I have the 26qt and first outing it did its intended job and like you I will be getting a 39qt for longer trips and use it as a base and carry just the 26 on trails / day usage.
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Yeah, at home, I actually use the 39QT for additional storage. Then roll I it out for soccer practice each Wednesday :) For the 19QT, that is always in my car, I just embedded the cigarette plug cable, ran it under the panels from one side of the trunk to the 12v plug side. Then each morning I plug in the AC adapter to make sure it is cold when I leave. I keep it at 20 degrees when at home at all times. Then especially when I hit the gym, where I'm usually parked for 2 hours in the sun, when I come back out, everything inside is still cold. I'll even leave a wet towel in there for use afterwards, its great :)
timhood
Tim
Several
I’ve got a 40-ish quart vertical which I think is ideal for the two-door because it uses less floor space. But I’m thinking that a smaller unit for shorter trips is also good. Camping with the large one and day trips or hotel-based road trips with the smaller one.
