Xjeepowner
Randy
Montgomery Texas
18 Camaro 16 JKU Rubicon
Very cool, I can’t imagine what it would be like to have such a great dad!
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
VERY COOL!
Featherless
Alan
Los Angeles
Very cool stuff! Does anyone know if this bronco is on a completely custom tubular chassis or does it share the actual platform/geometry of a production bronco?
userdude
userdude
Jared
Denton, TX
2023 2dr Badsquatch
@BAUS67 could tell you better I think, but the 4600 is the stock series. There's only a few things they can do. IMO they are reasonably stock, given the terrain.
BAUS67
redneck
Central PA
@Featherless more stock than you might think.
3.2 FRAME & BODY 3.2.1 Stock frame (frame is considered to be the primary frame rails and all permanently factory cross members) must be retained, and must be complete and unmodified. No material may be removed for any reason and no section of the frame may be 'massaged' or re-shaped with the following limitations and exceptions: The rear portion of the frame and rear cross member may be removed or trimmed for the sole purpose installing an aftermarket rear bumper. Frames may be reinforced by adding material. 3.2.2 Stock body (body is considered to be the full cab, including all interior and exterior sheet metal, bed, doors, hood, fenders, grill, etc.) required. The body must be complete and unmodified, with the following limitations and exceptions: Holes may be cut in any part of the body for the single and exclusive purpose of allowing roll cage tubes and transmission/transfer case linkage to pass-through the body. Holes may be cut in the firewall, grill and core support exclusively for roll cage. Roll cage includes the main 6-point structure that surrounds and protects the vehicle’s occupants. The roll cage also includes additional tubing designed to protect the structural integrity of the vehicle and its occupants and must be tied to the standard 6-point occupant cage. Additional tubes are limited to no more than 2 connecting 2021 Ultra4 Rulebook V5.1 36 tubes which may be ran through the bumper, grill or firewall, respectively and must connect to the A Pillar as close to the windshield frame as safely possible. Open holes must be kept to within .5"(12.5mm) of the diameter of any tube or linkage that passes through the body, with further restrictions related to holes in firewalls specified in Section 2.4.5. The exception to this rule is the allowance for rocker panel protection limited to the area between the wheel wells. You may cut into the body and/or reinforce this area. You may not interfere with the mating surface of the stock door and doorsill. The stock doorsill must be retained and unaltered.
Rule book found here if you need more info......
https://kingofthehammers.com/wp-content/uploads/2022/09/2021-Ultra4-Rulebook-V5.1_0.pdf
Featherless
Alan
Los Angeles
Wow, that is IMPRESSIVE!! 🙌😎🤘
