Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
INDUSTRY FIRST!
Factory Mounting Locations:
This upgrade utilizes factory mounting locations, making install a breeze.
Trail Ready™:Built to withstand all the elements whether you're driving on road or off, or with the top on or off.
Upgrade your 4-Door Ford Bronco's audio experience with our 10" subwoofer enclosure. Engineered for seamless integration, this add-on utilizes factory mounting locations, ensuring a hassle-free installation process. Built to endure the rigors of off-roading, it boasts durability against all elements, delivering powerful bass without compromising performance. Elevate your adventures with enhanced sound quality, perfect for tackling any terrain with unmatched audio immersion.
*This subwoofer add-on enclosure does not come amplified
*Patent Pending
*Comes with bracket to work with soft tops as well
Ford Bronco NOW AVAILABLE! The SSV Rear Subwoofer Enclosure Add-On for your 4-Door Bronco! 7fbdf892-5366-4825-9018-8d64d108a0f4
Ford Bronco NOW AVAILABLE! The SSV Rear Subwoofer Enclosure Add-On for your 4-Door Bronco! 6ec16b6c-bb31-444a-9e5f-96b639d3e1d4
Ford Bronco NOW AVAILABLE! The SSV Rear Subwoofer Enclosure Add-On for your 4-Door Bronco! 197601e1-34a2-4cfd-ad3c-479590106962
Ford Bronco NOW AVAILABLE! The SSV Rear Subwoofer Enclosure Add-On for your 4-Door Bronco! 4f709d84-a72e-460b-a005-5e5d04a56460
Ford Bronco NOW AVAILABLE! The SSV Rear Subwoofer Enclosure Add-On for your 4-Door Bronco! f3208ac8-95d0-4af9-abef-1f857aeabeb3
Ford Bronco NOW AVAILABLE! The SSV Rear Subwoofer Enclosure Add-On for your 4-Door Bronco! 3e04290d-5294-467a-979b-c8ae9c74f82f
Head on over to our site to see more details about our new Subwoofer Enclosure!
https://ssvworks.com/products/2021-and-up-ford-bronco-rear-subwoofer-add-on
You can DM us for a discount offered to our Bronco6G members also!
derichio02
Bo
Southern California
Bronco Badlands, Maverick, Tesla M3, F250 Tremor
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
derichio02
Bo
Southern California
Hey Bo,
Unfortunately it will not work with the Everglades, sorry for the confusion. We are making the edit on our page now.
Ok thank you. Is it because the slide out tailgate would touch the bottom of the enclosure or because the bracket is curved? The slide out tailgate mount to the same anchor point on the cargo floor and some washers or nylon spacers might make it fit. Has the team tried or did they just eyeball it? I’m willing to try if I would be able to return if that would help us both out 😁
DuneRunner
New England
This looks fantastic. Do you have the Theil Small parameters published for your SSV Sub? I am deciding between using your sub, Hertz, or a JL tw5
Kiddo44pct
NY
Chevy traverse
Would this fit if you have builtright molle on cargo area?
Draughon
Daylon
Dallas
BMW 4-Series
Nice guys! Brilliant product to bring to market!
mjp2
NJ
2021 Cyber Yellorange Bronco Badlands
That's a very nice offering. Clean, creative solution.
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
All good questions and we actually have not tested it. Im assuming that it uses the same mounting points as our sub but could be worth the try. You can definitely return it if it does not work out. Let me know what you think, thanks!
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
Unfortunately it does not look like it will work with the molle panels as it will block the area where the sub bolts up to.
Switchworks_Kyle
Switchworks_Kyle
Kyle
Oxnard California
2022 Ford Bronco
So I don't have the parameters available on the woofer. but the enclosure is .65cuft sealed. rigid design to reduce flex and fits most woofers upto 6.3" deep (depending on the motor structure)
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Ford Bronco NOW AVAILABLE! The SSV Rear Subwoofer Enclosure Add-On for your 4-Door Bronco! 7e015368-1582-433f-8ba2-570317d81d3f_text
