Status
Not open for further replies.
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Jeep LJ, Ford Ranger, Ford Bronco
Ford Bronco 20% OFF BRONCO ARB BUMPERS 27
Gear up for Summer and save BIG on ARB Bumpers for your Ford Bronco. From now until May 31, 2024, save 20% off any ARB Front or Rear Bumper for Ford Broncos. Use code 6GBRONCO
*BONUS* Order before April 30, 2024, and only pay $99 for Flat Rate Shipping*!
Ford Bronco 20% OFF BRONCO ARB BUMPERS 25
Summit Front Bumper
  • Classic ARB full protection brush guard with modern design enhancements​
  • Built-in winch mounting system for Warn winches up to 10,000lbs​
  • Twin jack points for easy recovery with farm jacks or ARB Jack​
  • Recovery points are conveniently located on both the left and right sides​
  • Inset LED parking/signal lights and mounting points for OE fog lights​
  • Features ARB Integrit finish (black texture powder coat) and EDP20 Ecoat for corrosion resistance​
  • Installed weight of 172lbs​
  • Compatible with ARB Under Vehicle Protection (PN 5480100)​
  • Clears up to 37” tire with suitable suspension lift and rim offset​
Ford Bronco 20% OFF BRONCO ARB BUMPERS 28
  • The newest addition to the ARB bumper family, the Zenith, offers essential off-road features with a minimalist design​
  • Features twin recovery and jack points similar to the ARB Summit​
  • Maintains factory parking sensors, adaptive cruise control radar, and forward-facing camera​
  • Removable front skid plate powder-coated silver, providing a customizable base layer​
  • Integrated LED Light Bar with 6900 RAW lumens output, including wiring harness​
  • Pre-assembled fog light housings for OE fog lights or optional ARB Fog Lights​
  • Available in two models for wide (Sasquatch Package and Wildtrak Trim Level) or narrow flare vehicles​
  • Additional Features:​
  • Installed weight of 133lbs​
  • Not winch compatible​
  • ARB's rear bumper retains the OE tow bar while accommodating rear parking sensors, with blank plugs provided for sensor-less models​
  • Powder coated with the same Integrit black coating as ARB front bumpers for a uniform look​
  • Includes a license plate relocation bracket to center the plate on the spare tire​
  • Features twin jack points and 8T recovery points for rear recovery needs​
  • Available in two widths to fit wide flare and narrow flare models​
  • ARB Integrit finish (black texture powder coat)​
  • Zinc-rich primer for enhanced corrosion resistance​
  • Installed weight of 155lbs​
Jkoep
HawIi
is this promotion available through 4wheelparts locations?
Monster1926
Indiana
GMC Sierra 2500HD
Hey Ryan, I added the summit bumper to my cart on ARBUSA and it’s still showing at $1780? Is there a coupon code I need to put in?
HOSSMAN
HOSS
Boerne "Burn-E", TX.
'23 Badlands '24 IS 350 F-Sport '26 150 Tremor
Do y'all have a pic of the "narrow flare" rear bumper on a Bronc?
archer87
TX
Bronco Wildtrak
Sorry for the dumb question, but which models have wide flares and which have narrow?
Is it Sasquatch = wide?
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Sorry forgot to add the code! (6GBRONCO)
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
Not a dumb question! Sasquatch and Wildtrak are the wide models.
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
HOSSMAN
HOSS
couldn't locate any photos but I came across this video (courtesy of Motoroso)
Thanks for the vid. Is that a "narrow flare" one in the video? My question comes in because the standard flare one looks super big, wondering how much more cut down the narrow is.
Ryan at ARB
Ryan at ARB
Ryan
Auburn, HI
arbusa.com
This is the narrow version which is roughly 1" narrower, per side.
Doug_life
Oregon
23 wt, 78 bronco
How much of a pita is it to add a winch after install? Would it be best to do both at the same time?
BigSkyBronco
Big Sky Country
'06 Wrangler Rubicon Unlimited - '96 Toyota FZJ80
Does anyone know the weight of the factory modular bumper? I'm trying to determine what the net gain is by adding the ARB. TIA!
NM! found it - ~80 lbs. So net gain of ~ 90lbs.
Status
