PWillette
Parrie
Maine
That certainly does look like a blast!
swamp2
Not enough rebound damping. Come of Fox, update your shock software.
Definitely nice air!
JohnGalt
JohnGalt
Tahoe, CA
2023 Defender 110
Actually, upon further reflection, I was probably in Normal mode.
I’d been running laps in Baja when I stopped (and turned off the truck) to talk to the guy who ultimately offered to film me. Im pretty sure I didn’t re-select Baja.
it seemed like a lot of rebound after watching it too many times.
the poacher
john
Whistler
2010 ford ranger
Very impressive, but as was pointed out, that is a heck of a lot of rebound. I don't believe putting it in Baja mode would create enough dampening. I would hope that the Fox system allows you to manually adjust the rebound.
JohnGalt
JohnGalt
Tahoe, CA
2023 Defender 110
Baja mode, maybe not. Definitely something I’ll be investigating further.
One consideration is that was a pretty dang big drop. While the wheels were only a foot or so off the ground I probably dropped down 12+ feet from wheel separation to landing. It’s a lot taller than it looks on camera. 🤪
the poacher
john
Whistler
2010 ford ranger
It was indeed a big drop, and your Raptor handled it well. Hopefully, some adjustments to your fox suspension will correct the damping.
Good luck, and a great vid by the way, thanks for sharing.
'18 M2
2023 Warthog
That looked fun. How fast were you going on the jump?
ironmike
2022 Bronco Raptor
Curious if you let off the gas pedal just before takeoff. It appears that the rig was nosing forward which contributed to the rebound…so that should have helped I think.
JohnGalt
JohnGalt
Tahoe, CA
2023 Defender 110
Yep, I got off the gas at/near departure.
vrtical
Doug AI
GSMNP, TN
Fords
There is a standalone aftermarket Fox system for fine tune adjustment if you want to go that hardcore, the F150 guys run it.
vrtical
Doug AI
GSMNP, TN
Fords
I blew a flare of at 42 mph landing ever soo slightly heavy passenger side, used all the travel then some lol
swamp2
FYI - Baja Mode would have helped significantly as it provides more compression and more rebound damping and is specifically for fast and tough terrain. You can "manually" adjust the Raptor suspension but only in that you can choose a GOAT mode or choose a suspension mode manually (the former just does the latter). The manual suspension options are Normal, Sport, Off-road and Baja. Individual compression or rebound adjustments would be well beyond 99% of owners...
