Phil B
Phil
Plano Texas
2023 Bronco Wildtrak
Curious if the install is the same as the Lumen kit I used, and if it requires programing.
SGXIX
What is the difference between this and the 4 pin curt aftermarket? Doesn't look like they tap into yhe battery terminal to install this
Itchysquatch
Luke
Vermont
99 4runner, 2014 E class
This is great. Thanks for sharing
capn00
Jared
Yardley, PA
2023 Bronco Heritage, 2018 GX460
I’m a DIY kind of guy but $120 for installation as listed I would just pay it.
After looking through the instructions, it was an easy decision for me to let the dealer install it. I used the 20% coupon for the harness, and my FordPass points to make the cost minimal. I installed the Curt hitch this week and will be making the appointment at the dealer for install of the harness the second week of September.
Tofudude
Chan
22 Brono Base Mansquatch
The bronco is already wired for the factory tow package. This kit just adds the module and the wiring harness to the trailer 7pin plug.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Yeah this kit has been available since late spring/early summer.
Our best guess is this is a similar to the kit that dealers will get for 2024MY Broncos now that the tow package for 24MY is a dealer installed option.
The only difference is the wiring for the 2024MY Broncos will already be there, while this kit requires you to tear apart a few of the factory connectors to install the missing pins/wires.
SGXIX
So pretty much 7 pin for $425 with installation included. Kind of difficult to justify price difference for 4 pin I got from Curt for $55...
Hdscreens
Will
2dr Bronco Badlands
Update us once installed and if the $120 install is actually all they charge?
SGXIX
How did you get discount to apply? says $300 minimum order amount.
capn00
Jared
Yardley, PA
I added a hitch plug and Molle straps to bump the cost over $300. Still a net savings
