8/29/2022 Build Week Group
Devious Tinker
Crystal
Dodge Durango
No Tear Tag or built email yet but I logged into the backdoor tracker to see this little gem.
Ford Bronco 8/29/2022 Build Week Group BroncoOrderStatus
Devious Tinker
Crystal
Dodge Durango
NoloBronco
Nolensville Tn
2022 Bronco Badlands SAS
Apparently only BCM modules. I have a tear tag and Built status and only BCM’s
Thank you. How long did it take the tracker to update? I am still showing in production with a date of 9/6 (yesterday).
Also can you explain the Tear Tag?
KS22WT
Kansas
Ford Explorer, Ford Mustang GT, Acura TLX
No luck with Anthony from Ford Performance Chat on getting my rail car # from my 9/4 shipped Bronco. Assuming his group is probably tired of getting requests? Will have to reach out to our dealer to see if we can get the info.
El Diablo
Roberto
San Carlos, CA
2018 Tesla Model 3 and 2022 Ford Bronco
Following in your footsteps. Checked the backdoor tracker and got the same built status but tear tag and built email are still lagging behind. I'm not worried so much about delivery date because I am in Asia until Oct so I have to coordinate with my dealer and make sure they don't sell my rig before I get back.
Devious Tinker
Crystal
Dodge Durango
My Tear tag finally populated so you should be seeing yours soon.
PiratePhil96
Philip
Raleigh, NC
Ford Ranger
Tear Tag is essentially just a code technicians use that gives them information on your vehicle, in the build process its mainly just used as another reference point to see something has happened in the process.
As far as tracker goes I had an 8/30 blend, tracker showed in production with a date of 9/2 (also the day modules popped). Tear Tag showed up 9/5 and then it switched to built overnight last night with a date of 9/6. Still no build email received. Hope that helps!
NoloBronco
Nolensville Tn
Thank you this does help. My only other question is where would I see the tear tag? Does it populate with the modules?
El Diablo
Roberto
San Carlos, CA
LykwidFire
Jamie
Newfoundland, Canada
2022 Ford Bronco Badlands
PiratePhil96
Philip
Raleigh, NC
Ford Ranger
It is on the same page as the modules, you should see it near the top, even if they haven't popped yet it will say Tear Tag and just be blank beside it.
Bronc6g22
Jake
Washington
Mazda 6, Tacoma TRDOR
