7spd weighted shift knob??
Lèòn
Jersey
Anyone go from Boomba to twisted?
BadSquatch
Wilmington, DE
72 Bronco
I can’t figure out which of the Twisted Shifters knobs will work with the Bronco.
Their description with the adapter say that most knobs will work, but they also say each knob will indicate if it works with the Bronco (ie.-just a couple of the cue ball designs).
Does anyone know if the majority of their knobs will work, or not?
Thanks.
huey
kevin
Ontario & Kentucky
@EIGHTLUG
allright, I am watching for the shifter knobs, when you have them will also order the console vin # pc and hopefully you have a badlands limited BAM BYODR hiding on the shelf
cheers
Lèòn
Jersey
Honestly, if those are your options, you just need to wait. #buyoncecryonce
I dont regret my decision, just asking if anyone has
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Thanks.
I emailed Twisted inquiring on the closest color green that would match the Eruption Green. They responded with a few greens, that were not listed on their "Bronco" list online. I got the impression that they could make any of them work for the Bronco. Just have to ask.
Twisted's response:
Probably closest is metallic green https://www.twistedshifterz.com/collections/solid-color/products/metallic-emerald-green-shift-knob
Plain green no metallic https://www.twistedshifterz.com/collections/solid-color/products/solid-green-shift-knob
Or, glitter green https://www.twistedshifterz.com/collections/glitter/products/green-glitter-shift-knob
And Pearl green https://www.twistedshifterz.com/collections/pearl/products/pearl-green-shift-knob
All can have the Bronco pattern in one of a few fill colors.
Let us know what you would like and we can invoice by email for the order.
Thank you,
Twisted Shifterz
www.TwistedShifterZ.com
bloominguez
Tom
Atlanta, GA
'22 Br BD, '22 5BW, '24 GR Corolla, '94 VFR, '04 SV
Honestly not bad, it blends very well giving an OEM look. There is a slight increase in overall height and with the reverse lockout but its not a bother to me. I don’t think it stands out much at all. Added another pic for reference
Apologies for ignorant questions....
I don't see that blue on their site. Custom order? Which blue is that? I may have missed details above, adapter needed?
BadSquatch
Wilmington, DE
72 Bronco
Bloominguez- You need to choose the one that says “build yours here!” . Under that, you can choose the color.
bloominguez
Tom
Atlanta, GA
Love the shift knob, looks and feels great.
The adapter kit, not so much. Should take advantage of the geometry to prevent rotation, not just rely on a tiny set screw. Really had to tighten the crap out of things to prevent rotation.
I got Metallic Blue, works great with the blue Bronco interior.
Also, because the adapter adds a small bit very significant of amount of height I wanted to make the knob as low as possible, which means that my shift pattern is not lined up properly. Would have to rotate it back (higher) 3/4 of a turn to line it up properly.
Overall I love the look and feel, but the adapter issues (not taking advantage of geometry and additional height) hold it back.
Picture of the Metallic Blue knob (rotated so that the pattern is in the right position, but the knob was a bit higher).
Ford Bronco 7spd weighted shift knob?? 1676298399272
Picture of the shaft, with notch that the stock shift knob uses for alignment & preventing rotation. This is what the Twisted Shifterz Bronco adapter does *not* take advantage of.
Ford Bronco 7spd weighted shift knob?? 1676298482032
Lèòn
Jersey
Now I gotta get that damn Boomba knob off, insert more color into my girl
Hkak45
K
Illinois
21 Bronco Black Diamond
Love mine put it at perfect position
What orientation is your set screw at for the adapter? I can not get mine to tighten enough where it doesn't just pop off from the spring
TNBronc4344
JT
Kingsport
Did you put the top screw back in? The one that came with the original shifter? That has to be in and it holds the adaptor down in place to keep it from frying off the spring. The set screw is just to keep it from turning. I love mine.
TNBronc4344
JT
Kingsport
Though I love my Twisted knob as soon as AR (EightLug) gets there’s out on the market I’m sure I will make the switch. I have everything else they make in this Bronco so what’s one one mortgage payment?! Lol.
