IAG Off-Road
JJ
Westminster, MD
www.iagperformance.com
We are excited to announce the development and production of the next product in our EZ lineup. With the EZ-Guide System, you will no longer have to worry about secure storage when you remove your Bronco's doors. Gone are the DIY days of building a makeshift contraption out of 2x4s, carpet, or PVC to store your doors. The EZ-Store Door Storage System features solid steel construction with a black powder-coated finish. The hexagon pattern design mimics our popular EZ-Steps.
SHOP NOW
KEEP YOUR DOORS OFF THE FLOOR
Ford designed the 2021+ Broncos to go straight from the showroom to the trail, with features like removable doors to lighten the vehicle and provide greater visibility. The IAG EZ-Guide Door Storage System mounts to the wall of your garage, giving you a safe place to hang your Bronco doors when they’re not in use. IAG’s Door Storage System protects your doors from potential dents, dings and scratches by keeping them up off the floor where they can get knocked over or bumped around. This space-saving system doubles as a storage solution for your IAG I-Line tube doors, which can be stored out of the way during the winter months when you're using your OEM doors. We offer hangers for two & four door model front doors, four door model rear doors, or a four door front and rear door combo kit.
Ford Bronco IAG EZ-Guide Door Storage System lighter-jpg
HEAVY-DUTY CONSTRUCTION
The IAG EZ-Guide Door Storage System is constructed of heavy-duty steel and has a durable black powder-coated finish that is resistant to corrosion and scratches. Part of the EZ-Guide Door Storage System are the molded urethane cradles that guide the doors into position on their mounts, and keep them stationary while in storage. This system was designed for ease of use; to store the doors simply slide them into the molded urethane cradles until they are resting on the hinge pins. It’s that easy!
EASY TO ASSEMBLE AND USE
The IAG EZ-Guide Door Storage System is easy to assemble and mount. There is no need to purchase wall lags or any additional hardware, the EZ-Guide Door Storage System includes all the hardware you’ll need to put it together and fasten securely to the wall. We've even included extra brackets to accommodate 16" or 24" studs. Please note that due to the weight of the doors, this system must be mounted to the wall studs.
A BETTER DESIGN FOR SAFER STORAGE
Other door storage systems mount in a way that leaves the painted exterior side of the door exposed to the garage, leaving it susceptible to accidental scratches and damage. The IAG EZ-Guide Storage System keeps your doors stored with the exterior paint safely facing the garage wall, so you won’t have to worry about mishaps with bikes or kids. IAG’s Storage System was designed so that you can remove the door and place it directly into the EZ-Guide Storage System without having to set it down on the floor to reposition it for mounting.
LIFETIME WARRANTY
We're proud to offer a limited Lifetime Warranty on the IAG EZ-Guide Door Storage System. In the unlikely event of a structural failure excluding powder coating, we will provide free repair or replacement for life to the original purchaser.
SHOP NOW
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Wow, these are actually pretty cool. And price isn't bad either. I would imagine you would still want to put the door storage bags on while utilizing this system......I wouldn't want the painted side of my doors up against my wall, or still exposed in general.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
You can absolutely still use your door bags and we would echo your sentiments about using them. We made them so that the painted side is towards the wall so that you never have to worry about scratching them as you walk by them or work in the garage. The painted door itself CANNOT hit the wall as the handle will touch first.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
Need to see:
* How the doors dont touch the wall or metal brackets
* How to use with door bags on
everyone will ask this so they need to show this first
The door bags will just slip on. You can use OEM, ours, or likely any other aftermarket bag you may find. We do recommend placing and removing the doors from the hanger with the door bags removed so that you can grab the lifting point at the bottom of the door.
Ford Bronco IAG EZ-Guide Door Storage System 367517860_299221362656517_1512840844157699687_n
Ford Bronco IAG EZ-Guide Door Storage System 367514544_301851175855559_1097199648053608029_n
Bruno
Bruno
Sierras
Super helpful and exciting thank you!!
I assume your tube doors can store on these as well?
Have you considered a 4 door Dube Door and Storage System total package?
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
Looks like a good design. I assume tube doors would also work? $500 for 4 door setup is a bit pricey compared to the competition.
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
Tube doors will require a slightly different adapter (just pull the urethane piece off and replace it with the adapter when putting the tube doors on) that we will offer down the road. We have been working on these for quite a while now and wanted to get them into the market as soon as we could as we recognize we were a little behind the 8-ball on their release.
Our EZ-Guide Door Storage system is designed, engineered, and manufactured right here in our Westminster, MD facility. We feel it is the best-engineered solution currently on the market. It has a full mounting bracket system that will accommodate 16" or 24" on center stud construction which will ensure the system always stays securely mounted to the wall. There is some serious weight hanging on there with the doors installed, and we went with overbuilt and secure. We also have urethane adapters that allow the doors to be placed almost exactly like installing them on your truck, stop them from swinging, and prevent any damage to the hinges. Lastly, having the painted side towards the wall as we do with our system not only prevents accidental damage to the paint while walking through the garage, but also makes it significantly easier to hang the door. So if you think about how you take the doors off, if you were to put the painted side out on the wall - you pick the door up from the inner door panel side. You would then need to spin the door somehow so the painted side is toward you. Now you open yourself up to scratching the paint with your belt buckle or buttons and also don't have a great way to really hold the door while you are hanging it. Then do it all again in reverse when you want to put the doors back on. That seemed silly to us so we designed a better solution.
Nabor19
Minnesota
2023 Bronco Black Diamond; 1994 Corvette
Well designed product from the looks of it. Solves many if the problems with the other ones on the market with the mounting bar to grab two studs and mounting the doors handle in. Good job!
Second Nature Overland
Keith
North Texas, US
www.youtube.com
2023 Ford Bronco Badlands Sasquatch 4-door
Glad to see these are now available. I had a chance to check out the 2-door and the 4-door prototype at Super Cel East earlier this year, and I really liked what I saw. I may just have to buy one!
Bsenecal
Vermont
'19 Ranger crew cab, '17 Fusion sport, '68 Mustang
SHOP NOW
LIFETIME WARRANTY
SHOP NOW
Just ordered one.
VelocityGator
98 4Runner
Wow, these look great. I have a two door and have cinder block garage walls. Tap con hardware included to handle the weight of the doors mounted into cinder block? May I see a picture of the mounting hardware? Looking forward to possibly purchasing.
Red Squatch
Butler Pa.
1997 Cobra convertible
Tap Cons are made for solid concrete like slabs or poured walls. The odds are pretty good the threads would pull out under the weight of your doors, I would use some kind of toggle type anchor.
JPG
Montreal, Qc, Canada
Bronco Badlands
Very nice product, good job. Now for a hard top section storage solution ? ( either wall or trolley like ) ;)
IAG Off-Road
IAG Off-Road
JJ
Westminster, MD
It will come with lag bolts for wood stud installation, but a trip to the hardware store will allow for just about any installation type. The doors are heavy though, and I would agree with the one poster that tapcons wouldn't be my ideal for a cinder block wall and would go with a toggle anchor of the proper weight rating.
