- Chris
- Mar 18, 2022
- 23
- 447
- 951
- Hemet, CA
- Website
- lobooffroad.com
- All of them
- Wildtrak
Protect your Bronco’s HOSS 3.0 FOX Shocks from trail damage with these beefy, specific-application Rear Shock Skids from Lobo Off-Road.
These skids are designed around the FOX 2.5 piggyback shock that comes on factory-equipped Wildtrak Broncos with HOSS 3.0 (optional on 2022, standard on 2023 and newer Wildtrak). The skid has a faceted front face that protects the piggyback reservoir but provides angled surfaces to lessen drag on the rocks.
The components are CNC laser cut from 3/16″ plate steel, brake-formed and fixture-welded for a perfect fit. They come with a durable fine-textured satin black powder coat finish, but if you’re using them the way they are intended you’ll probably be touching them up with a rattle can from time to time.
Get yours from the Lobo Off-Road website by Clicking Here!
UPDATE! ALUMINUM VERSION NOW AVAILABLE!
There is now a version of this Shock Skid available in 3/16" aluminum. It is left bare (no powder coating) revealing the item's beautiful TIG welds. While materials and working with aluminum are slightly more expensive, not needing to powder coat them offsets costs so that the price is the same as the steel ones.
PROs of the aluminum version are
- They are about 1/3 the weight of steel, for those who are taking every opportunity they can to save weight
- They will not rust and therefore will not need to be touched up with paint whenever they get scraped up
- They look badass!
