Bigred86
Curt
Thurmont, Maryland
2022 Ford Bronco, 2016 Harley Davidson Sportster48
Lets make a photo section for everyone with custom grilles. Painted, wrapped, aftermarket swapped. Anything different then what came on your Bronco, share it here!
JCSmith
Joe
New Jersey
2002 Suburban
Ford Bronco Post Your Custom Bronco Grille! 9165EF30-28EF-4013-BA86-B6D201AF41B3
Nothing “over the top”, but Eruption Green turned out to be tricky to pair up with another color, so I settled on Chrome letters. I had Black letters for a little while, it looked “ok”, but the Chrome is alot nicer than the factory White letters and the Black, and looks good without being cheap looking or flashy. (I typically hate plastic chrome)
The black grille inserts are the best, I hated how chaotic my grill looked before installing these.
The Driving Viking
Northeast
2022 Bronco Sasquatch 2022 Willys Xtreme Recon
Rtr but I’m already tired of it about to swap out to a black diamond grille.
It looks really good. But I think I would miss the BRONCO on the grille. Maybe you do?
Jazer
Jessica
2.7 OBX
Not much, just the black letter covers & grill inserts.
Ford Bronco Post Your Custom Bronco Grille! PXL_20230501_155001890~3
Ford Bronco Post Your Custom Bronco Grille! PXL_20230502_171133011
Frankie945
Frank
Louisville KY
Q50
Think it looks fugly combined with the amber drl. I’ve unplugged the rtr lights since putting the Morimoto headlights in. Looks ok together when I change them to white but I kinda like the amber look.
Ford Bronco Post Your Custom Bronco Grille! IMG_1008
Ford Bronco Post Your Custom Bronco Grille! IMG_1016
The Driving Viking
Northeast
Yeah and the amber lighting is good for fog or dusty environments. The RTR grille also complements the bumper you went with.
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
I just wish that I could change the letters. They cam black and they're a bit bigger than the OEM letters. I would prefer to be able to make them blue or even red.
Jazer
Jessica
2.7 OBX
Will an overlay not work? How off is the sizing?
Mikerocks
Corpus Christi, TX
2017 F150
you can always plastidip them. really easy to do
SubmarineNuke
Richard
Houston, TX
twitch.tv
Bronco Wildtrak
They're "bigger" than the OEM letters, and for example the R is almost hard to tell it's an R.
I've thought about removing them, using an automotive spray paint and then putting them back on, but that means taking the grill off completely and some other work and it's not just a 10 minute job to remove, paint, dry, reinstall etc etc.
Jazer
Jessica
2.7 OBX
PM me some measurements and I can cut you a set to try. These are some I drew up & cut (I have made some for a few other locals as well). I can size up my file to fit your measurements and you can give it a try if you'd like. I am out of this particular blue but have a few other blues and I think some red. We can always test a file and then if it fits perfectly you can send me a small sheet of a color you want to use and I would be happy to re-cut them.
Ford Bronco Post Your Custom Bronco Grille! 1683292045409
