7.3L in the Bronco?!
BONESTOCK
MA
Lightning, Mach 1, Falcon
Man!! I'd poop my pants if Ford did this!
All I know is I will be putting this into my Gen 1 Lightning backed by my TKO 600.
OX1
jackson nj
59 Bird, 70, 74, 78, 79 Broncos, 84 LTD 331 w/Vortech, 86 Capri 5.0 turbo, 14 Stang GT, 17 Fusion Sport
Probably weighs less than the super common swap into EB's, 351w's that had cast iron heads/intake/exh manifolds
and all cast or stamped steel access brackets/pulleys.
And yes, one of those will be going in possibly upwards of 3 of my cars/trucks.
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Whose got the popcorn?
BONESTOCK
MA
Yup. Says it weighs just about the same as my 351 Windsor in the Gen 1.
Rogues Gambit
Eatontown, NJ
I mean....it fits in a fox body. Should easily fit in the new Bronco!
More you'll see them discuss why it should be, so there'll be some fireworks
I'm certain it'd work, but I'm not an expert
OX1
jackson nj
Where did you find the weight? Been looking for that and external dimensions.
BAUS67
redneck
Central PA
I think I'm in love ……..... I always dreamed of a big block in my fox body. The Procharged small block just doesn't seem to cut it anymore. After I buy my Bronco of course.
wjfawb0 [hacked account]
Tennessee
2015 Jeep Wrangler JKR
The Godzilla engine was designed to pass emissions and be reliable at low rpm with long oil change intervals. It can make big numbers, but you'd probably be better off with a coyote or hurricane variant if you want power. However, with enough money, you can do anything, right?
Tslater1989
Tyler
Central Michigan
2001 f150, 2016 explorer, 97 f150
Thats what I tell my wife. I can do just about anything with enough time and money.
OX1
jackson nj
First try on doing anything to it and they are @ 588HP.
And much smaller than we all originally thought.
Stampede.Offroad
SD
junk
First few minutes they spend measuring them, very nice.
I'm surprised how 'small' the 7.3 is.
